Impossible d’installer Big Sur sur MacBook Pro 2019, un message d’erreur apparaît. Je vous poste la photo du message :
Je vous envoie ça au cas où :
Last login: Fri Jan 1 23:37:48 on console
macbook-pro-de-tulzinn:~ tulzinn$ diskutil list
/dev/disk0 (internal):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme 251.0 GB disk0
1: EFI EFI 314.6 MB disk0s1
2: Apple_APFS Container disk1 250.7 GB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +250.7 GB disk1
Physical Store disk0s2
1: APFS Volume Macintosh HD 36.1 GB disk1s1
2: APFS Volume Preboot 112.5 MB disk1s2
3: APFS Volume Recovery 510.4 MB disk1s3
4: APFS Volume VM 1.1 GB disk1s4
/dev/disk2 (disk image):
0: GUID_partition_scheme +12.9 GB disk2
1: EFI EFI 209.7 MB disk2s1
2: Apple_HFS Shared Support 12.6 GB disk2s2
macbook-pro-de-tulzinn:~ tulzinn$ diskutil mount disk2s1
Volume EFI on disk2s1 mounted
