diskutil list
Last login: Mon Apr 9 21:37:30 on console
macbook-pro:~ macbookpromaxime$ diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *250.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS OS X Base System 149.7 GB disk0s2
3: Apple_Boot Recovery HD 100.0 GB disk0s3
csrutil status
df -H /Volumes/"OS X Base System"
Last login: Mon Apr 9 22:07:50 on ttys000
macbook-pro:~ macbookpromaxime$ df -H /Volumes/"OS X Base System"
Filesystem Size Used Avail Capacity iused ifree %iused Mounted on
/dev/disk0s2 150G 16G 133G 11% 437138 4294530141 0% /
diskutil rename disk0s2 "Macintosh HD"
Last login: Mon Apr 9 22:50:51 on ttys000
2: Apple_HFS Macintosh HD 149.7 GB disk0s2
sudo asr adjust --t /dev/disk0s3 --settype "Apple_HFS"
diskutil list
Last login: Mon Apr 9 22:51:09 on ttys000
macbook-pro:~ macbookpromaxime$ sudo asr adjust --t /dev/disk0s3 --settype "Apple_HFS"
Password:
Fsck /dev/disk0s3 ....10....20....30....40....50....60....70....80....90....100
Adjust completed successfully
Last login: Mon Apr 9 22:56:05 on ttys000
3: Apple_HFS Recovery HD 100.0 GB disk0s3
diskutil mount disk0s3
df -H /Volumes/"Recovery HD"
Last login: Mon Apr 9 23:03:32 on ttys000
macbook-pro:~ macbookpromaxime$ df -H /Volumes/"Recovery HD"
/dev/disk0s3 100G 542M 100G 1% 19 4294967260 0% /Volumes/Recovery HD
diskutil resizeVolume disk0s3 %recovery% free null 0b
diskutil list
Last login: Mon Apr 9 23:18:30 on ttys000
3: Apple_HFS Recovery HD 650.0 MB disk0s3
diskutil umount force disk0s3
sudo asr adjust --t /dev/disk0s3 --settype "Apple_Boot"
diskutil list
Last login: Mon Apr 9 23:28:18 on ttys000
3: Apple_Boot Recovery HD 650.0 MB disk0s3
diskutil resizeVolume disk0s2 0b
diskutil list
