Agents launchd :
[En marche] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installé 2018-05-10)
[Engagé] com.microsoft.update.agent.plist (Microsoft Corporation - installé 2018-07-21)
[Pas engagé] com.adobe.SwitchBoard.monitor.plist (? 5bc5da98 - installé 2018-05-10)
[Pas engagé] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installé 2018-05-10)
[Pas engagé] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installé 2018-05-31)
[Engagé] com.oracle.java.Java-Updater.plist (? 93b2eaa8 - installé 2018-02-21)
Daemons launchd :
[Engagé] com.intel.haxm.plist (? 42f307e7 - installé 2018-05-03)
[Engagé] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installé 2018-07-21)
[Pas engagé] org.virtualbox.startup.plist (? 700b9385 - installé 2018-03-07)
[Engagé] com.adobe.SwitchBoard.plist (? 856489a3 - installé 2018-05-10)
[En marche] com.adobe.acc.installer.plist (Adobe Systems, Inc. - installé 2018-03-14)
[Engagé] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installé 2018-02-02)
[Engagé] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installé 2018-02-21)
[En marche] com.adobe.agsservice.plist (Adobe Systems, Inc. - installé 2018-05-31)
[En marche] com.adobe.agmservice.plist (Adobe Systems, Inc. - installé 2018-05-31)
[Engagé] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installé 2018-02-11)
Agents launchd de l’utilisateur :
[Engagé] com.google.keystone.agent.plist (Google, Inc. - installé 2018-07-10)
[En marche] com.github.facebook.watchman.plist (? 0 - installé 2018-06-19)
[Engagé] com.logmein.GoToMeeting.G2MUpdate.plist (LogMeIn, Inc. - installé 2018-04-24)
[Engagé] com.citrixonline.GoToMeeting.G2MUpdate.plist (LogMeIn, Inc. - installé 2018-04-05)
[Engagé] com.adobe.AAM.Updater-1.0.plist (? 0 - installé 2018-03-14)
Modules internets :
FlashPlayer-10.6: (installé 2018-02-23)
QuickTime Plugin: (installé 2018-06-15)
Flash Player: (installé 2018-02-23)
JavaAppletPlugin: (installé 2018-02-21)
Panneaux de préférences de tiers :
Flash Player (installé 2018-02-02)
Java (installé 2017-03-15)
Time Machine :
Time Machine pas configuré !
Utilisation de l’unité centrale par opération :
Opération (nombre) Source % de l’unité centrale Lieu
mdworker (27) Apple 169
mds_stores Apple 13
com.apple.WebKit.WebContent Apple 10
mds Apple 10
WindowServer Apple 10
Utilisation de la mémoire par opération :
Opération (nombre) Source Usage de mémoire Lieu
kernel_task Apple 834 Mo
mdworker (27) Apple 783 Mo
Adobe CEF Helper (3) Adobe Systems, Inc. 290 Mo
com.apple.WebKit.WebContent Apple 249 Mo
mds_stores Apple 202 Mo
Utilisation du réseau par opération :
Opération Source Entrée Sortie Lieu
mDNSResponder Apple 17 Ko 13 Ko
apsd Apple 5 Ko 16 Ko
com.apple.WebKit.Networking Apple 5 Ko 2 Ko
netbiosd Apple 522 o 354 o
SystemUIServer Apple 0 o 128 o
Utilisation de l’énergie par opération :
Opération (nombre) Source Énérgie (0-100) Lieu
mdworker (27) Apple 25
suggestd Apple 5
mds_stores Apple 5
WindowServer Apple 3
mds Apple 3
Informations de la mémoire virtuelle :
Mémoire disponible : 3.82 Go
Mémoire libre : 317 Mo
Mémoire utilisé 4.18 Go
Cache du fichier : 3.51 Go
Fichier d’échange utilisé : 0 o
Installations de logiciel (30 derniers jours) :
Nom Version Date d’installation
Intel(R) Hardware Accelerated Execution Manager 7.2.0 2018-07-12
Microsoft AutoUpdate 4.1.18070503 2018-07-21
Événements du diagnostic (7 dernier jours si pas grave) :
2018-07-19 21:02:38 Runner.app Plantage
/Users/***/Library/Developer/CoreSimulator/Devices/36DF3D66-F92D-4DFF-97DA-E53622808787/data/Containers/Bundle/Application/BABEF439-5A51-4AB0-8886-848AF52CDDB8/Runner.app
2018-07-17 19:52:55 com.apple.WebKit.WebContent Plantage (2 fois)
/System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Bundle controller class:
BrowserBundleController
2018-07-15 18:54:23 Microsoft Word.app Plantage
/Applications/Microsoft Word.app
Performing @selector(terminate
from sender NSMenuItem 0x6000004b70a0
Fin du rapport
