-bash-3.2# diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_CoreStorage Macintosh HD 499.2 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
/dev/disk1 (disk image):
0: GUID_partition_scheme +2.1 GB disk1
1: Apple_HFS OS X Base System 2.0 GB disk1s1
/dev/disk2 (internal, virtual):
0: Apple_HFS Macintosh HD +498.9 GB disk2
Logical Volume on disk0s2
89D929AE-0C53-4339-9113-62ED80638329
Unencrypted
/dev/disk3 (disk image):
0: untitled +5.2 MB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +524.3 KB disk6
/dev/disk7 (disk image):
0: untitled +2.1 MB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +524.3 KB disk9
/dev/disk10 (disk image):
0: untitled +12.6 MB disk10
/dev/disk11 (disk image):
0: untitled +4.2 MB disk11
/dev/disk12 (disk image):
0: untitled +1.0 MB disk12
/dev/disk13 (disk image):
0: untitled +2.1 MB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +524.3 KB disk15
/dev/disk16 (disk image):
0: untitled +1.0 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +6.3 MB disk18
/dev/disk19 (disk image):
0: untitled +524.3 KB disk19
/dev/disk20 (disk image):
0: untitled +2.1 MB disk20
rm /Volumes/"Macintosh HD"/var/db/caches/opendirectory/*
kextcache -u /Volumes/"Macintosh HD"
-bash-3.2# rm /Volumes/"Macintosh HD"/var/db/caches/opendirectory/*
rm: /Volumes/Macintosh HD/var/db/caches/opendirectory/*: No such file or directory
-bash-3.2# kextcache -u /Volumes/"Macintosh HD"
-bash-3.2#
diskutil mount disk2
ls /Volumes/Mac*/var/db/caches/opendirectory
diskutil info disk2
-bash-3.2# diskutil info disk2
Device Identifier: disk2
Device Node: /dev/disk2
Whole: Yes
Part of Whole: disk2
Device / Media Name: APPLE HDD HTS545050A7E362
Volume Name: Macintosh HD
Mounted: Yes
Mount Point: /Volumes/Macintosh HD
Content (IOContent): Apple_HFS
File System Personality: Journaled HFS+
Type (Bundle): hfs
Name (User Visible): Mac OS Extended (Journaled)
Journal: Journal size 40960 KB at offset 0x15497000
Owners: Enabled
OS Can Be Installed: Yes
Booter Disk: disk0s3
Recovery Disk: disk0s3
Media Type: Generic
Protocol: SATA
SMART Status: Verified
Volume UUID: B44B5D11-608E-33AE-A6C8-51AD5E5F98C5
Disk / Partition UUID: 89D929AE-0C53-4339-9113-62ED80638329
Disk Size: 498.9 GB (498887294976 Bytes) (exactly 974389248 512-Byte-Units)
Device Block Size: 512 Bytes
Volume Total Space: 498.9 GB (498887294976 Bytes) (exactly 974389248 512-Byte-Units)
Volume Used Space: 449.2 GB (449217994752 Bytes) (exactly 877378896 512-Byte-Units) (90.0%)
Volume Free Space: 49.7 GB (49669300224 Bytes) (exactly 97010352 512-Byte-Units) (10.0%)
Allocation Block Size: 4096 Bytes
Read-Only Media: No
Read-Only Volume: No
Device Location: Internal
Removable Media: Fixed
Solid State: No
Virtual: Yes
Hardware AES Support: No
This disk is a Core Storage Logical Volume (LV). Core Storage Information:
LV UUID: 89D929AE-0C53-4339-9113-62ED80638329
LVF UUID: 9013DB9B-FCC0-4904-97AC-5A2E9BD78FB5
LVG UUID: 47886EE1-D777-4BB7-B756-34A7F56F4C43
PV UUID (disk): E5A75FEE-25AA-48A8-9F4F-85B9393C9E06 (disk0s2)
Fusion Drive: No
Encrypted: No
Oui, j'ai effectivement acquis beaucoup de films-séries-mangas-divertissement durant ces vacances et c'est pour cela que la taille occupée a augmenté de cette manière (il doit avoir un peu plus de 200go de ça).Tu as 449 Go de données (Système & perso) alors que la 1ère fois tu en avais 244 Go
cette fois-ci : impossible. Il te faut absolument un DDE USB pour servir de destination au clonage. Genre un 500 Go. Sans ça > je ne peux rien faire...
/Volumes/"Macintosh HD"/usr/bin/du -shx /Volumes/"Macintosh HD"/Users/delnah/*
