iMac iMac (2012) bloqué au démarrage sur la Pomme, help
voila :
-bash-3.2# diskutil info /Volumes/"Macintosh HD"
   Device Identifier:        disk0s2
   Device Node:              /dev/disk0s2
   Part of Whole:            disk0
   Device / Media Name:      Customer
   Volume Name:              Macintosh HD
   Mounted:                  Yes
   Mount Point:              /Volumes/Macintosh HD
   File System Personality:  HFS+
   Type (Bundle):            hfs
   Name (User Visible):      Mac OS Extended
   Owners:                   Enabled
   Partition Type:           Apple_HFS
   OS Can Be Installed:      No
   Recovery Disk:            disk0s3
   Media Type:               Generic
   Protocol:                 SATA
   SMART Status:             Verified
   Volume UUID:              CC864E90-6D10-3CF6-ADB5-CB9D035D6DF8
   Disk / Partition UUID:    0000360C-1C56-0000-170B-000024520000
   Total Size:               999.3 GB (999345127424 Bytes) (exactly 1951845952 512-Byte-Units)
   Volume Free Space:        129.0 GB (129046867968 Bytes) (exactly 252044664 512-Byte-Units)
   Device Block Size:        512 Bytes
   Allocation Block Size:    4096 Bytes
   Read-Only Media:          No
   Read-Only Volume:         Yes
   Ejectable:                No
   Whole:                    No
   Internal:                 Yes
   Solid State:              No
-bash-3.2#
Alors passe les 3 commandes (séparément) :
diskutil list
df -H
  • la 1ère affiche les informations sur le volume remonté
  • la 2è le tableau des disques --> et montrera les paramètres du DDE
  • la 3è mesure l'occupation de tous les volumes montés
Poste toutes ces informations.
Je vais commenter ensuite ton tableau d'informations. Passe encore les 2 commandes :
diskutil list
df -H
  • de mon message précédent > et poste leurs retours
=> on saura tout.
voila les 3 premier commende :
   Mounted:                  Yes
   Type (Bundle):            hfs
   Owners:                   Enabled
   Media Type:               Generic
   Protocol:                 SATA
   Read-Only Media:          No
   Ejectable:                No
   Whole:                    No
   Internal:                 Yes
   Solid State:              No
-bash-3.2# diskutil list
/dev/disk0
   2:                  Apple_HFS Macintosh HD            999.3 GB   disk0s2
/dev/disk1
   0:     Apple_partition_scheme                        *1.3 GB     disk1
   1:        Apple_partition_map                         30.7 KB    disk1s1
   2:                  Apple_HFS OS X Base System        1.3 GB     disk1s2
/dev/disk2
   0:                            untitled               *5.2 MB     disk2
/dev/disk3
   0:                            untitled               *524.3 KB   disk3
/dev/disk4
   0:                            untitled               *524.3 KB   disk4
/dev/disk5
   0:                            untitled               *524.3 KB   disk5
/dev/disk6
   0:                            untitled               *524.3 KB   disk6
/dev/disk7
   0:                            untitled               *524.3 KB   disk7
/dev/disk8
   0:                            untitled               *6.3 MB     disk8
/dev/disk9
   0:                            untitled               *2.1 MB     disk9
/dev/disk10
   0:                            untitled               *1.0 MB     disk10
/dev/disk11
   0:                            untitled               *524.3 KB   disk11
/dev/disk12
   0:                            untitled               *524.3 KB   disk12
/dev/disk13
   0:                            untitled               *1.0 MB     disk13
/dev/disk14
   0:                            untitled               *6.3 MB     disk14
-bash-3.2# df -H
les 2 dernier :
/dev/disk0
/dev/disk1
/dev/disk2
/dev/disk3
/dev/disk4
/dev/disk5
/dev/disk6
/dev/disk7
/dev/disk8
/dev/disk9
/dev/disk10
/dev/disk11
/dev/disk12
/dev/disk13
/dev/disk14
-bash-3.2# df -H
oui merde ! dans la présipitation et dans le couchage des enfants, j'ai oublier de le branché !
je répét l'opération avec de suite, desolé !
Branche ton DDE au Mac. Une fois que tu l'as fait --> repasse uniquement les 2 commandes suivantes (l'une après l'autre) :
diskutil list
df -H
  • qui vont afficher le tableau des disques et l'occupation des volumes montés.
Poste ces 2 tableaux. Je saurai alors si le disque du DDE a les bons paramètres. Et j'aurai une confirmation de la taille des données dans les volumes.
petite question avent : j'ai renomé mon disc dur externe en le vidant : "Sauvgarde Time Machine" cela ne pose pas de probleme ? ( reconnécance automatique ...)
/dev/disk0
/dev/disk1
/dev/disk2
/dev/disk3
/dev/disk4
/dev/disk5
/dev/disk6
/dev/disk7
/dev/disk8
/dev/disk9
/dev/disk10
/dev/disk11
/dev/disk12
/dev/disk13
/dev/disk14
/dev/disk15
   0:      GUID_partition_scheme                        *1.0 TB     disk15
   1:                        EFI EFI                     209.7 MB   disk15s1
   2:                  Apple_HFS Sauvegarde Time Machine 999.9 GB   disk15s2
-bash-3.2#
et le dernier :
-bash-3.2# df -H
Filesystem      Size   Used  Avail Capacity   iused     ifree %iused  Mounted on
/dev/disk1s2    1.3G   1.3G    31M    98%    317417      7638   98%   /
devfs           201k   201k     0B   100%       680         0  100%   /dev
/dev/disk2      5.2M   1.8M   3.4M    35%       442       836   35%   /private/var/log
/dev/disk3      524k   147k   377k    29%        34        92   27%   /Volumes
/dev/disk4      524k   143k   381k    28%        33        93   26%   /private/var/tmp
/dev/disk5      524k   160k   365k    31%        37        89   29%   /private/var/run
/dev/disk6      524k   143k   381k    28%        33        93   26%   /System/Installation
/dev/disk7      524k   283k   242k    54%        67        59   53%   /private/var/db
/dev/disk8      6.3M   3.2M   3.1M    51%       775       759   51%   /private/var/folders
/dev/disk9      2.1M   1.5M   614k    71%       360       150   71%   /private/var/root/Library
/dev/disk10     1.0M   152k   897k    15%        35       219   14%   /Library/ColorSync/Profiles/Displays
/dev/disk11     524k   172k   352k    33%        40        86   32%   /Library/Preferences
/dev/disk12     524k   168k   356k    33%        39        87   31%   /Library/Preferences/SystemConfiguration
/dev/disk13     1.0M   143k   905k    14%        33       221   13%   /Library/Keychains
/dev/disk14     6.3M   176k   6.1M     3%        41      1493    3%   /private/var/tmp/RecoveryTemp
/dev/disk0s2    999G   870G   129G    88% 212475159  31505583   87%   /Volumes/Macintosh HD
/dev/disk15s2   1000   664M   999G     1%    162026 243944640    0%   /Volumes/Sauvegarde Time Machine
-bash-3.2#
Alors analyse -->
dans les informations du volume > voici la principale :
  • volume monté en lecture seule. C'est l'indice constant d'un système de fichiers corrompu de façon irréparable > qui a permis par chance (rare) un remontage du volume en mode faible (lecture seule). Le volume n'est donc pas scriptible > mais lisible et donc clonable.
dans le tableau des disques > voici le DDE :
/dev/disk15
  • bien paramétré (bravo !) mais avec un nom "impossible" (= malcommode à saisir dans un terminal) --> qu'on va simplifier
dans le tableau de l'occupation des volumes -->
  • on voit que Macintosh HD contient 870 Go de données > et qu'en regard le volume Sauvegarde Time Machine est vide (664 Mo).
Passe la commande cosmétique :
diskutil rename disk15s2 Clone
  • la commande renomme le volume Sauvegarde Time Machine --> Clone
Parfait. Alors hop ! opération clonage.
Passe d'abord la commande :
caffeinate -dimsu &
  • qui va empêcher le Mac de dormir pendant l'opération ; elle passe sans commentaire
Passe ensuite la commande :
cp -av /Volumes/"Macintosh HD"/* /Volumes/Clone
  • mets "Macintosh HD" aves des "" ; pas d'espace entre HD" et /* ; un espace entre /* et /Volumes--
  • la commande clone Macintosh HD dans Clone
  • une ligne s'affiche par fichier copié
  • la copie suit l'ordre alphabétique des dossiers > sous-dossiers > fichiers
=> si tu vois un défilé de lignes démarrer à l'écran > c'est que le clonage est lancé. Attends jusqu'à l'arrêt du défilé et au retour de l'invite de commande -bash-3.2# en signal de complétion. Tu peux laisser ton Mac sans surveillance. Préviens quand tout est fini.
Bonsoir macomaniac !
j'ai du avoir le retour de la commande -bash-3.2# dans la fin de matinée ou début d'âpre midi, ( clone ok )
quelle sont les étape en suite
merci
Passe la commande :
df -H /Volumes/Clone
  • la commande mesure l'occupaiton du volume Clone
