MacBook Air parfaitement compatible avec Mojave. Qui sera un meilleur OS.
Donc passe la commande :
diskutil ap deleteContainer disk2 "Macintosh HD"
  • respecte les espaces libres ; mets "Macintosh HD" avec les ""
  • la commande supprime l'apfs > et reformate un volume Macintosh HD réinstallable
Poste l'affichage retourné.
-bash-3.2# diskutil ap deleteContainer disk2 ¨Macintosh HD¨
Usage:  diskutil apfs deleteContainer <containerRefDisk> [<name>]
        diskutil apfs deleteContainer <physicalStoreDisk> [<name>]
        diskutil apfs deleteContainer -force <physicalStoreDisk> [<name>]
        where <containerRefDisk> = Container Reference DiskIdentifier
              <physicalStoreDisk> = DiskIdentifier to use if Container damaged
              <name> = a new name (base) for the old Physical Store(s)
Delete an APFS Container. All of its APFS Volumes will be deleted, and all of
its former APFS Physical Store disks will be reformatted as HFS. Data on all
APFS Volumes will be lost. You can specify the Container by its Container
Reference disk or by its Physical Store disk. You can optionally specify a new
name for your reformatted disk(s), or else "Untitled" will be chosen; if
there were multiple Physical Stores, a space and a number suffix is added for
each. The "-force" option can be used as a last resort to reclaim your disk(s)
in case of Container damage, in which case you must specify a Physical Store
disk and you might have to manually delete any other "peer" (Fusion) Physical
Stores which defined the Container. Ownership of the affected disks is required.
Example:  apfs deleteContainer disk5
-bash-3.2#
Tu as fais une erreur de saisie de Macintosh HD à la fin. Tu as tapé des espèces de double points ¨ . Il s'agit de guillemets droits " (la touche du chiffre 3 en AZERTY sans presser la touche maj).
Repasse la commande exacte :
  • écris bien "Macintosh HD" à la fin avec les guillemets droits "" (ils ont pour rôle d'emballer l'espace libre central dans un intitulé unique d'objet)
effectivment :o
-bash-3.2# diskutil ap deleteContainer disk2 "Macintosh HD"
Unmounting Volumes
Unmounting Volume "Macintosh HD" on disk2s1
Unmounting Volume "Preboot" on disk2s2
Unmounting Volume "Recovery" on disk2s3
Unmounting Volume "VM" on disk2s4
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Initialized /dev/rdisk0s2 as a 113 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
Finished APFS operation on disk2
-bash-3.2#
Parfait : opération accomplie -->
- dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Réinstaller macOS" => et choisis Macintosh HD comme destination lorsque cela te sera proposé.​
Réactions: Kalsifer
Bonjour! J’ai de nouveau un problème d’allumage avec mon iMac ..... Help
Merci à celui qui pourra m’aider
Rebonjour Macomaniac !
Tout marchait comme sur des roulettes depuis que tu m'a aidé il y'a quelques jours.
Aujourd'hui, voulant revendre mon mac j'ai décidé de formater le disque... evidement rien ne se passe comme prévu haha
j'ai donc fait la commande pour avoir les 4 utilitaires et suivant un tuto, j'ai effacé le disque interne mac HD. En redémarant je suis retombé sur la fichue croix noire (et je me suis enervé haha)
J'ai donc essayé de reinstaller l'OS mais voila : on me parle maintenant d'installer OS X Mavericks et lors de la selection du disk il n'y en a pas, je ne peux donc pas réinstaller.
note: et l'ordi est passé en anglais tout seul
Au plaisir de te lire,
Kalsifer
    122,6 KB · Affichages: 91
Tu as démarré par internet sur un OS de secours d'usine du Mac (téléchargé en RAM) = Mavericks.
Redémarre (Menu  > Redémarrer) > et tiens aussitôt pressées les 3 touches : ⌘⌥R (cmd alt R) = second type de démarrage par internet -->
- qui va télécharger en RAM un OS de secours Mojave et démarrer le Mac dessus à la fin.​
Lorsque tu as l'écran affichant une fenêtre de 4 Utilitaires macOS > lance le Terminal > passe une commande :
diskutil list
  • et poste le tableau des disques --> que je voie la configuration du disque interne.
Le voici, j'arrive bien sur la page de l'OS Mojave et le disk macHD m'est proposé. Je n'ai pas osé lancé la réinstallation de l'OS
-bash-3.2# diskutil list
   2:                 Apple_APFS Container disk2         121.1 GB   disk0s2
/dev/disk1 (disk image):
   1:                  Apple_HFS macOS Base System       2.0 GB     disk1s1
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +121.1 GB   disk2
                                 Physical Store disk0s2
   1:                APFS Volume Macintosh HD            20.5 KB    disk2s1
   2:                APFS Volume Preboot                 21.6 MB    disk2s2
   3:                APFS Volume Recovery                519.0 MB   disk2s3
   4:                APFS Volume VM                      1.1 GB     disk2s4
/dev/disk3 (disk image):
/dev/disk4 (disk image):
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
/dev/disk10 (disk image):
/dev/disk11 (disk image):
/dev/disk12 (disk image):
/dev/disk13 (disk image):
/dev/disk14 (disk image):
/dev/disk15 (disk image):
/dev/disk16 (disk image):
/dev/disk17 (disk image):
/dev/disk18 (disk image):
/dev/disk19 (disk image):
   0:                            untitled               +6.3 MB     disk19
/dev/disk20 (disk image):
   0:                            untitled               +524.3 KB   disk20
/dev/disk21 (disk image):
   0:                            untitled               +2.1 MB     disk21
-bash-3.2#
Passe la commande :
  • respecte les espaces ; mets "Macintosh HD" avec les ""
  • la commande supprime l'apfs et reformate un volume Macintosh HD réinstallable
Unmounting Volumes
Deleting Volumes
Deleting Container
Mounting disk
-bash-3.2#
Parfait : tu peux lancer l'option : "Réinstaller macOS" --> en prenant Macintosh HD comme destination lorsque cela te sera proposé.
- note : une fois Mojave réinstallé en format apfs > le Mac va redémarrer sur l'OS installé proprement. Dans l'objectif d'une revente > tu ne devrais pas paramétrer alors le Mac ni créer un 1er compte d'utilisateur. Mais lorsque tu vois s'afficher le 1er écran de paramétrage du Mac réinstallé (le panneau de choix du Pays) => tu devrais éteindre ton Mac de force (pression continue sur le bouton d'alimentation). Ainsi > au prochain rallumage du Mac > l'OS Mojave installé proprement se rechargera et hop ! derechef s'affichera le 1er écran paramétrage du Mac. Au nouvel acquéreur d'embrayer alors pour configurer le Mac puis créer un nouveau compte admin.​
Réactions: Kalsifer
Je ne m'en sors pas malgré la vingtaine de pages précédentes... :(
Une idée pour réinstaller le tout correctement ?
   2:                 Apple_APFS Container disk2         250.8 GB   disk0s2
   0:      APFS Container Scheme -                      +250.8 GB   disk2
   1:                APFS Volume Macintosh HD            5.2 GB     disk2s1
   2:                APFS Volume Preboot                 40.0 MB    disk2s2
   5:                APFS Volume Sans titre              5.2 GB     disk2s5
-bash-3.2#
Bonjour GNEYR
Passe la commande directe :
  • respecte tous les espaces ; mets "Macintosh HD" avec les ""
  • la commande supprime l'apfs et reformate un volume Macintosh HD standard
Bonjour GNEYR
Merci !
Unmounting Volumes
Unmounting Volume "Sans titre" on disk2s5
Deleting Volumes
Deleting Container
Initialized /dev/rdisk0s2 as a 233 GB case-insensitive HFS Plus volume with a 24576k journal
Mounting disk
-bash-3.2#
Parfait -->
- dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Réinstaller macOS" --> et choisis Macintosh HD comme destination lorsque cela te sera proposé.​
Réactions: GNEYR
