10.14 Mojave Problème avec Fusion Drive pour clean Install - Mac crash a chaque commande de terminal
Et voici le retour, cela ressemble de plus en plus à ce que je vois d'habitude :
diskutil ap createContainer -main disk3s2 -secondary disk2s2 ; diskutil list
Creating container with disk3s2 disk2s2
Started APFS operation on disk3s2 SDD
Creating a new empty APFS Container
Unmounting Volumes
Switching disk3s2 to APFS
Switching disk2s2 to APFS
Creating APFS Container
FusionLC autodetect: regular Fusion
Created new APFS Container disk4
Disk from APFS operation: disk4
Finished APFS operation on disk3s2 SDD
/dev/disk0 (internal):
   0:      GUID_partition_scheme                         1.0 TB     disk0
   2:                 Apple_APFS Container disk1         1.0 TB     disk0s2
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +1.0 TB     disk1
                                 Physical Store disk0s2
   1:                APFS Volume ImacDisk                385.7 GB   disk1s1
   2:                APFS Volume Preboot                 48.1 MB    disk1s2
   3:                APFS Volume Recovery                510.4 MB   disk1s3
/dev/disk2 (external):
   0:      GUID_partition_scheme                         2.0 TB     disk2
   2:                 Apple_APFS Container disk4         2.0 TB     disk2s2
/dev/disk3 (external):
   0:      GUID_partition_scheme                         121.3 GB   disk3
   1:                        EFI EFI                     314.6 MB   disk3s1
   2:                 Apple_APFS Container disk4         121.0 GB   disk3s2
/dev/disk4 (synthesized):
   0:      APFS Container Scheme -                      +2.1 TB     disk4
                                 Physical Stores disk2s2, disk3s2
Bien.
Avant d'ajouter un volume installable dans le Conteneur > passe la commande informative :
diskutil ap list disk4
  • qui affiche le tableau détaillé du Conteneur apfs du Fusion Drive
=> poste le tableau > qui permettra de vérifier si les "performance roles" (rôles efficaces) sont bien attribués respectivement à chaque disque.
Voici ce que j'obtiens :
+-- Container disk4 BF4D0D30-11BD-42AC-9EA4-C2585BB99C75
    APFS Container Reference:     disk4 (Fusion)
    Size (Capacity Ceiling):      2121207386112 B (2.1 TB)
    Capacity In Use By Volumes:   8909492224 B (8.9 GB) (0.4% used)
    Capacity Not Allocated:       2112297893888 B (2.1 TB) (99.6% free)
    +-< Physical Store disk2s2 3EF0F48F-E47B-4BE8-ADC3-C940CD4A40E5
    |   APFS Physical Store Disk:   disk2s2 (Secondary, Designated Aux Use)
    |   Size:                       2000189177856 B (2.0 TB)
    +-< Physical Store disk3s2 BC023A1E-F8AD-462E-B124-F63BF654CB68
    |   APFS Physical Store Disk:   disk3s2 (Main)
    |   Size:                       121018208256 B (121.0 GB)
    +-> No Volumes
Ces mentions -->
  • montrent bien que : a) le magasin de stockage Physical Store inscrit dans la partition du HDD (disk2s2) => a bien le performance role "Secondary" comme requis (= stockage) > b) le magasin de stockage Physical Store inscrit dans la partition du SDD (disk3s2) => a bien le performance role "Main" comme requis (= vitesse). Tout est en ordre.
Passe la commande de finition :
diskutil ap addVolume disk4 apfs "Macintosh HD" ; diskutil list
  • la commande ajoute un volume Macintosh HD dans le Conteneur du Fusion Drive > puis réaffiche encore le tableau des disques
Poste tout l'affichage retourné.
Réactions: DjafaOS
Voici le retour de la commande :
Exporting new APFS Volume "Macintosh HD" from APFS Container Reference disk4
Started APFS operation on disk4
Preparing to add APFS Volume to APFS Container disk4
Creating APFS Volume
Created new APFS Volume disk4s1
Mounting APFS Volume
Setting volume permissions
Disk from APFS operation: disk4s1
Finished APFS operation on disk4
   1:                APFS Volume Macintosh HD            798.7 KB   disk4s1
Comme tu peux le voir -->
  • le Conteneur apfs collectif du Fusion Drive => héberge un volume Macintosh HD prêt à l'emploi
Je pense que ton problème est formellement résolu. Il te reste à réinstaller et récupérer tes données...
Je te confirme. A partir d'ici je reprends la main.
Je te remercie beaucoup, j'ai passé plusieurs heures pour essayer de m'en sortir avec mes commandes classiques.
Merci énormément.
Pour le retour d'expérience, le Volume "Macintosh HD" était absent lorsque j'ai démarré sur la console de récupération. Il a été créer sur l'iMac que j'utilisais pour récupérer le second, je ne comprends pas pourquoi, en disque externe.
Néanmoins via le terminal dans le Recovery mode, j'ai relancé à partir du post #22, et j'ai pu continuer normalement avec un volume "Macintosh HD" créé.
