je pense avoir fait une mauvaise manipulation avec mon terminal et ça me donne ça :
E325: ATTENTION
Found a swap file by the name "/var/tmp/hosts.swp"
owned by: root dated: Thu Apr 22 09:23:05 2010
file name: /ect/hosts
modified: YES
user name: root host name: macbook-pro-de-alain-nouri.local
process ID: 621
While opening file "/ect/hosts"
(1) Another program may be editing the same file.
If this is the case, be careful not to end up with two
different instances of the same file when making changes.
Quit, or continue with caution.
(2) An edit session for this file crashed.
If this is the case, use ":recover" or "vim -r /ect/hosts"
to recover the changes (see ":help recovery").
If you did this already, delete the swap file "/var/tmp/hosts.swp"
to avoid this message.
Swap file "/var/tmp/hosts.swp" already exists!
[O]pen Read-Only, (E)dit anyway, (R)ecover, (D)elete it, (Q)uit, (A)bort:
que faire ?
E325: ATTENTION
modified: YES
process ID: 621
que faire ?
