Non non tous les ports fonctionnent et sont non connectés. Je tente avec le Bluetooth désactiver et je te tiens au jus.
2021-02-01 22:47:43 +0100 Sleep Entering Sleep state due to 'Idle Sleep': Using Batt (Charge:61%) 1557 secs
2021-02-01 23:13:40 +0100 DarkWake DarkWake from Standby [CDN] : due to EC.LidClose/Maintenance Using BATT (Charge:61%) 13 secs
2021-02-01 23:13:53 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:61%) 2335 secs
2021-02-01 23:52:48 +0100 Wake Wake from Standby [CDNVA] : due to EC.LidOpen/UserActivity Assertion Using BATT (Charge:60%) 137 secs
2021-02-01 23:55:05 +0100 Sleep Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:60%) 887 secs
2021-02-02 00:09:52 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:60%) 5 secs
2021-02-02 00:09:57 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:60%) 897 secs
2021-02-02 00:24:54 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:60%) 5 secs
2021-02-02 00:24:59 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:60%) 897 secs
2021-02-02 00:39:56 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:60%) 5 secs
2021-02-02 00:40:01 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:60%) 897 secs
2021-02-02 00:54:58 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:59%) 5 secs
2021-02-02 00:55:03 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:59%) 897 secs
2021-02-02 01:10:00 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:60%) 5 secs
2021-02-02 01:10:05 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:60%) 897 secs
2021-02-02 01:25:02 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:60%) 5 secs
2021-02-02 01:25:07 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:60%) 897 secs
2021-02-02 01:40:04 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:59%) 5 secs
2021-02-02 01:40:09 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:59%) 897 secs
2021-02-02 01:55:06 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:59%) 5 secs
2021-02-02 01:55:11 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:59%) 10797 secs
2021-02-02 04:55:08 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:59%) 5 secs
2021-02-02 04:55:13 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:59%) 3597 secs
2021-02-02 05:55:10 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:60%) 5 secs
2021-02-02 05:55:15 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:60%) 10797 secs
2021-02-02 08:55:12 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:59%) 5 secs
2021-02-02 08:55:17 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:59%) 3597 secs
2021-02-02 09:55:14 +0100 DarkWake DarkWake from Standby [CDN] : due to RTC/Maintenance Using BATT (Charge:59%) 5 secs
2021-02-02 09:55:19 +0100 Sleep Entering Sleep state due to 'Maintenance Sleep': Using Batt (Charge:59%) 4247 secs
2021-02-02 11:06:06 +0100 Wake Wake from Standby [CDNVA] : due to EC.LidOpen/UserActivity Assertion Using BATT (Charge:59%)
MacBook-Air-de-Admin:~ admin$ pmset -g log | grep "due"
2021-02-02 20:46:44 +0100 Sleep Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:53%) 28802 secs
2021-02-03 04:46:46 +0100 DarkWake DarkWake from Deep Idle [CDN] due to RTC/SleepService: Using BATT (Charge:49%) 0 secs
2021-02-03 04:46:46 +0100 Sleep Entering Sleep state due to 'Sleep Service Back to Sleep': Using Batt (Charge:49%) 14468 secs
2021-02-03 08:47:54 +0100 Wake Wake from Standby [CDNVA] due to EC.LidOpen/Lid Open: Using BATT (Charge:49%) 151 secs
2021-02-03 08:50:25 +0100 Sleep Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:49%) 897 secs
pmset -g custom
Battery Power:
lidwake 1
autopoweroff 1
standbydelayhigh 86400
autopoweroffdelay 28800
standbydelaylow 10800
standby 1
ttyskeepawake 1
highstandbythreshold 50
powernap 0
gpuswitch 2
hibernatefile /var/vm/sleepimage
hibernatemode 3
displaysleep 5
sleep 5
acwake 0
halfdim 1
lessbright 1
disksleep 10
AC Power:
lidwake 1
autopoweroff 1
standby 1
ttyskeepawake 1
hibernatemode 3
powernap 1
gpuswitch 2
displaysleep 60
womp 1
networkoversleep 0
sleep 60
acwake 0
halfdim 1
disksleep 0
sudo pmset -b displaysleep 3 disksleep 4 sleep 5 hibernatemode 25 autopoweroff 0 standbydelayhigh 300 standbydelaylow 300
2021-02-03 23:33:33 +0100 Sleep Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:100%) 29578 secs
2021-02-04 07:46:31 +0100 Wake Wake from Standby [CDNVA] due to EC.LidOpen/Lid Open: Using BATT (Charge:100%) 84 secs
2021-02-04 07:47:55 +0100 Sleep Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:100%) 45807 secs
2021-02-04 20:31:22 +0100 Wake Wake from Standby [CDNVA] due to EC.LidOpen/Lid Open: Using BATT (Charge:100%)
Bonjour,Ce n'est pas tcpkeepalive (option absente) > mais ttyskeepawake (une fonction de terminal dont je ne connais pas le rôle pendant le sommeil du Mac). Curieusement > j'ai un Mac avec Mojave où les 2 options existent pour pmset.
Je suis ardemment ce topic car j'ai aussi quelques soucis avec mes macBooks (dont je parlerai une autre fois (quand j'aurai fait des tests plus précis)).
- ttyskeepawake prevent idle system sleep when any tty (such as a remote login session) is active; a tty is inactive only when its idle time exceeds the system sleep timer, 1 to enable or 0 to disable
Battery Power:
lidwake 1
autopoweroff 0
autopoweroffdelay 259200
standbydelaylow 300
standby 1
ttyskeepawake 1
hibernatemode 25
displaysleep 3
sleep 5
acwake 0
halfdim 1
sms 0
lessbright 1
disksleep 4
AC Power:
lidwake 1
autopoweroff 1
standbydelayhigh 4200
standbydelaylow 4200
standby 1
ttyskeepawake 1
hibernatemode 3
womp 0
displaysleep 10
networkoversleep 0
sleep 10
acwake 0
halfdim 1
sms 0
disksleep 0
Merci macomaniac pour ton analyse.Bonjour Shav
Les préférences pour l'alimentation sur batterie sont les plus rigoureuses possibles pour conserver la charge de batterie.
- quand tu fermes de capot => cela force directement le sommeil-Système du Mac pendant un délai de 300" = 5' avant virage à l'hibernation.
Tu parles ici d'une extinction immédiate du Mac ? Car le choix d'un mode d'hibernation 25 induit le comportement suivant : à la mise en sommeil-Système du Mac (déclenchée par le rabat du capot) > la RAM est sauvegardée à un fichier sleepimage du disque puis désactivée dans le foulée. Au relèvement du capot > la RAM se trouve rechargée à partir du fichier sleepimage > ce qui donne un réveil demandant un laps de temps à cause de ce processus. Tu n'as pas ce comportement ?
