MacBook Pro Problème hibernation/mise en veille après changement SSD
Hello @macomaniac @lasperule @ericse @Locke le test de cette nuit est plutôt concluant
Je l'ai laissé en veille à 95% de batterie, ce matin à 10h 92%, je pense que les réglages ne sont pas optimaux mais pas de reboot.
Le log
2020-09-18 21:41:13 +0200 Sleep                   Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:95%) 1394 secs
2020-09-18 22:04:27 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to EC.LidOpen/Lid Open Using BATT (Charge:95%) 46 secs
2020-09-18 22:05:13 +0200 Sleep                   Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:95%) 25 secs
2020-09-18 22:05:38 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to EC.LidOpen/UserActivity Assertion Using BATT (Charge:97%)
2020-09-18 22:17:47 +0200 Assertions              PID 319(UserEventAgent) Summary BackgroundTask "com.apple.coreduet.sync.update-source-device-identifiers" 00:05:59  id:0x0xb000080db [System: PrevIdle DeclUser kDisp]
2020-09-18 22:18:02 +0200 Sleep                   Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:95%) 42391 secs
2020-09-19 10:04:33 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to EC.LidOpen/UserActivity Assertion Using BATT (Charge:92%)
2020-09-19 10:04:51 +0200 Assertions              PID 319(UserEventAgent) Released BackgroundTask "com.apple.coreduet.sync.update-source-device-identifiers" 11:53:03  id:0x0xb000080db [System: PrevIdle DeclUser IntPrevDisp kDisp]
Et le pmset loin d'être opti à mon avis :
Battery Power:
 lidwake              1
 autopoweroff         1
 standbydelayhigh     86400
 autopoweroffdelay    259200
 standbydelaylow      10800
 standby              1
 ttyskeepawake        1
 highstandbythreshold 50
 powernap             0
 gpuswitch            2
 hibernatefile        /var/vm/sleepimage
 hibernatemode        3
 displaysleep         2
 sleep                1
 acwake               0
 halfdim              1
 lessbright           1
 disksleep            0
AC Power:
 lidwake              1
 autopoweroff         1
 standby              1
 ttyskeepawake        1
 hibernatemode        3
 powernap             1
 gpuswitch            2
 displaysleep         10
 womp                 1
 networkoversleep     0
 sleep                1
 acwake               0
 halfdim              1
 disksleep            0
Passe la commande :
sudo pmset -b displaysleep 3 disksleep 4 sleep 5 hibernatemode 25 autopoweroff 0 standbydelayhigh 300 standbydelaylow 300
  • qui revient aux réglages préconisés à mon message #19. Redémarre ensuite une fois et re-teste.
Passe la commande :
J'ai la même config alors j'ai essayé sans trop y croire... et le Mac a planté lors du réveil, obligé de forcer l'arrêt et redémarrer :
2020-09-19 13:08:26 +0200 Sleep                   Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:100%)
2020-09-19 13:08:41 +0200 Assertions              PID 122(apsd) Released InteractivePushServiceTask "com.apple.apsd-requestkeepaliveproxy-push.apple.com" 00:00:15  id:0x0x1200009513 [System: DeclUser kDisp]
2020-09-19 13:08:43 +0200 Wake Requests           [*process=powerd request=UserWake deltaSecs=139027 wakeAt=2020-09-21 03:45:50 info="com.apple.alarm.user-visible-Weekly Usage Report,291"]
2020-09-19 13:08:43 +0200 PM Client Acks          Delays to Sleep notifications: [com.apple.apsd is slow(17033 ms)]
2020-09-19 17:29:17 +0200 ShutdownCause           SMC shutdown cause: 3: Power button pressed for > 4 sec
2020-09-19 17:29:19 +0200 HibernateStats          hibmode=0 standbydelaylow=0 standbydelayhigh=0                                           0
Sleep/Wakes since boot at 2020-09-17 19:47:29 +0200 :0   Dark Wake Count in this sleep cycle:7
Time stamp                Domain                  Message        Duration      Delay
UUID: Unknown UUID
2020-09-19 17:29:19 +0200 Failure                 Failure during sleep: 0x119140E0000001F : EFI/Bootrom Failure after last point of entry to sleep
UUID: (null)
2020-09-19 17:29:19 +0200 Start                   powerd process is started
2020-09-19 17:29:19 +0200 BatteryHealth           Battery health: Check Battery; was: Good
2020-09-19 17:29:19 +0200 Assertions              Summary- [System: No Assertions] Using Batt(Charge: 96)
Passe la commande :
Hello,
Thanks, je modifie et refais le test cette nuit.
@ foflarage
Passe la commande :
sudo pmset -b displaysleep 2 disksleep 0 sleep 1 hibernatemode 3 autopoweroff 1 standbydelayhigh 86400 standbydelaylow 10800
  • qui remet exactement ce que tu avais au départ. Redémarre.
ok bon c'est problématique, avec les nouveaux paramétrages je retombe sur mes pbs de reboot....
Qu'est-ce que je disais déjà ? Ah oui : tu devrais lire mes messages, tu gagnerais du temps :coucou:
Tu l'avais dit ça? My bad je n'avais pas vu...
Du coup re-test cette nuit, et pas soucis de reboot avec les réglages d'origine
Le log
2020-09-19 22:16:30 +0200 Sleep                   Entering Sleep state due to 'Idle Sleep': Using Batt (Charge:60%) 165 secs
2020-09-19 22:19:15 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to XHC1/HID Activity Using BATT (Charge:60%)
2020-09-19 22:26:05 +0200 Assertions              PID 311(UserEventAgent) Summary BackgroundTask "com.apple.coreduet.sync.update-source-device-identifiers" 00:02:05  id:0x0xb000080f0 [System: No Assertions]
2020-09-19 22:26:34 +0200 Sleep                   Entering Sleep state due to 'Idle Sleep': Using Batt (Charge:58%) 664 secs
2020-09-19 22:37:38 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to EC.LidOpen/UserActivity Assertion Using BATT (Charge:58%) 133 secs
2020-09-19 22:39:36 +0200 Assertions              PID 311(UserEventAgent) Summary BackgroundTask "com.apple.coreduet.sync.update-source-device-identifiers" 00:15:37  id:0x0xb000080f0 [System: PrevIdle DeclUser IntPrevDisp kDisp]
2020-09-19 22:39:51 +0200 Sleep                   Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:57%) 1994 secs
2020-09-19 23:13:05 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to EC.LidOpen/UserActivity Assertion Using BATT (Charge:57%) 242 secs
2020-09-19 23:16:52 +0200 Assertions              PID 311(UserEventAgent) Summary BackgroundTask "com.apple.coreduet.sync.update-source-device-identifiers" 00:52:52  id:0x0xb000080f0 [System: PrevIdle DeclUser kDisp]
2020-09-19 23:17:07 +0200 Sleep                   Entering Sleep state due to 'Clamshell Sleep': Using Batt (Charge:55%) 28805 secs
2020-09-20 07:17:12 +0200 DarkWake                DarkWake from Deep Idle [CDN] : due to RTC/SleepService Using BATT (Charge:53%) 0 secs
2020-09-20 07:17:12 +0200 Sleep                   Entering Sleep state due to 'Sleep Service Back to Sleep': Using Batt (Charge:53%) 900 secs
2020-09-20 07:17:13 +0200 PM Client Acks          Delays to Sleep notifications: [PLPowerEventListener is slow(884 ms)] [com.apple.bluetooth.sleep is slow(884 ms)] [PLSleepWakeAgent is slow(884 ms)] [com.apple.apfsd is slow(884 ms)] [mDNSResponder is slow(891 ms)] [IPConfiguration is slow(892 ms)] [com.apple.time is slow(920 ms)] [com.apple.time is slow(930 ms)] [com.apple.duetactivityscheduler is slow(931 ms)] [com.apple.apsd is slow(994 ms)] [systemstats is slow(1123 ms)] [AirPort configd plug-in is slow(1373 ms)]
2020-09-20 07:32:12 +0200 DarkWake                DarkWake from Deep Idle [CDN] : due to RTC/Maintenance Using BATT (Charge:53%) 0 secs
2020-09-20 07:32:12 +0200 Sleep                   Entering Sleep state due to 'Idle Sleep': Using Batt (Charge:53%) 900 secs
2020-09-20 07:47:12 +0200 DarkWake                DarkWake from Deep Idle [CDN] : due to RTC/Maintenance Using BATT (Charge:53%) 0 secs
2020-09-20 07:47:12 +0200 Sleep                   Entering Sleep state due to 'Idle Sleep': Using Batt (Charge:53%) 900 secs
2020-09-20 07:47:14 +0200 PM Client Acks          Delays to Sleep notifications: [com.apple.bluetooth.sleep is slow(1096 ms)] [com.apple.time is slow(1096 ms)] [PLSleepWakeAgent is slow(1096 ms)] [com.apple.apfsd is slow(1096 ms)] [IPConfiguration is slow(1097 ms)] [com.apple.duetactivityscheduler is slow(1097 ms)] [com.apple.time is slow(1122 ms)] [systemstats is slow(1130 ms)] [AirPort configd plug-in is slow(1155 ms)] [com.apple.apsd is slow(1385 ms)]
2020-09-20 08:02:12 +0200 DarkWake                DarkWake from Deep Idle [CDN] : due to RTC/Maintenance Using BATT (Charge:52%) 0 secs
2020-09-20 08:02:12 +0200 Sleep                   Entering Sleep state due to 'Idle Sleep': Using Batt (Charge:52%) 813 secs
2020-09-20 08:02:40 +0200 PM Client Acks          Delays to Sleep notifications: [com.apple.time is slow(1023 ms)] [com.apple.bluetooth.sleep is slow(1024 ms)] [com.apple.duetactivityscheduler is slow(1024 ms)] [com.apple.apfsd is slow(1024 ms)] [PLSleepWakeAgent is slow(1025 ms)] [mDNSResponder is slow(1039 ms)] [IPConfiguration is slow(1050 ms)] [com.apple.time is slow(1057 ms)] [com.apple.time is slow(1057 ms)] [PLPowerEventListener is slow(1083 ms)] [systemstats is slow(1089 ms)] [AirPort configd plug-in is slow(1116 ms)] [com.apple.apsd timed out(28010 ms)]
2020-09-20 08:15:45 +0200 Wake                    Wake from Deep Idle [CDNVA] : due to EC.LidOpen/Lid Open Using BATT (Charge:51%)
   pid 311(UserEventAgent): [0x00000033000b80f0] 09:56:35 BackgroundTask named: "com.apple.coreduet.sync.update-source-device-identifiers"
C'est vrai que c'est sympa de donner son retour d'expérience :up:
Mais, à moins que tu ais d'autres avis, imagine que sur ton MB tu as un petit problème matériel ... qui perturbe et crée ce genre de désagrément ... et qu'après le test de l'ami foflarage lui n'ait pas de problème ...
Là, au-moins, vous êtes sûr ! ;)
Toujours pour info.
Rien à redire depuis le changement et la modification suggérée par macomaniac avec mon MBP (early 2015) et le nouveau Transcend JetDrive 850 240GB
Toujours pour info.
Hello,
Tu peux me rappeler le paramétrage en question please?
De mon côté, je pense que je ne vais plus toucher aux paramétrages (bien qu'ils soient aberrants) vu que mon MBP se comporte "normalement", après ces problèmes de reboot me paraissent incompréhensibles...
Hello,
Celle postée dans le message #4
Je te propose de passer la commande expérimentale suivante (copier-coller) -->
Une fois la commande passée > redémarre une fois pour que le nouveau paramétrage soit pris en charge par le kernel (le moteur du système démarré). Fais le test pendant une nuit (Mac sur batterie, charge de batterie à 100% au moment de la mise-en-sommeil-système (forcée par rabat du couvercle ou automatique après 5' d'inactivité en session couvercle maintenu levé). Tu n'auras qu'à dire si tu te trouves mieux de ces réglages.
je m'incruste dans la discussion, excusez moi d'avance ...
je suis à bout !!!!
Alors mon souci est celui ci: J'ai toujours eu pour habitude de fermer mon écran après une session de travail sur mon macbook pro.
Il est pas tout eune (2010) mais est toujours réactif.
J'ai un DDSSD, 8 GO de RAM sous High Sierra. DD changé l'année dernière.
Donc pour revenir à mes moutons, quand j'ouvre à nouveau l'écran, il ne rallume pas tout seul, comme avant. Je dois forcer son redémarrage (j'appuie sur le bouton power 8sec 1 pression supplémentairement et ça se rallume)
Merci pour votre aide
Last login: Wed Oct 7 06:18:04 on console
Battery Power:
lidwake 1
ttyskeepawake 1
hibernatemode 0
displaysleep 2
sleep 10
acwake 0
halfdim 1
sms 1
lessbright 1
disksleep 0
AC Power:
lidwake 1
ttyskeepawake 1
hibernatemode 3
womp 1
displaysleep 10
networkoversleep 0
sleep 10
acwake 0
halfdim 1
sms 1
disksleep 10
Tu pourrais commencer par rétablir les réglages par défaut : Préférences système > Economiseur d'énergie > Rétablir les réglages par défaut (il y a plusieurs boutons, un par onglet)
Merci ericse,
je n'ai pas tous les boutons mais j'ai rétabli et snif rien ne change je suis toujours bloqué lors de la veille je dois forcer le démarrage ...m'énerve ça
Màj d'info.
J'ai fait une installation propre de Big Sur 11.0.1 sur mon MBP (ssd d'origine remplacé par ssd Transcend 240GB) et me voilà de retour avec le problème de perte d'autonomie de la batterie en veille : perte d'environ 5% par heure de veille.
Si je compare le rapport pmset à l'origine du problème (sous Catalina) et celui-ci (sous Big Sur) j'ai quasi les mêmes caractéristiques :
pmset à l'époque du bug en Catalina
Last login: Thu Sep 10 10:03:49 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
MacBook-Pro-de-ADMIN:~ admin$ pmset -g custom
Battery Power:
lidwake              1
autopoweroff         1
autopoweroffdelay    28800
standby              1
proximitywake        0
ttyskeepawake        1
hibernatemode        3
gpuswitch            2
powernap             0
displaysleep         2
sleep                1
acwake               0
halfdim              1
tcpkeepalive         1
lessbright           1
disksleep            10
AC Power:
lidwake              1
autopoweroff         1
proximitywake        1
standby              1
ttyskeepawake        1
hibernatemode        3
powernap             1
gpuswitch            2
womp                 1
displaysleep         0
networkoversleep     0
sleep                0
tcpkeepalive         1
halfdim              1
acwake               0
disksleep            10
pmset à l'époque du bug en Big Sur
Last login: Sun Nov 22 09:54:18 on console
Battery Power:
 lidwake              1
 autopoweroff         1
 standby              1
 proximitywake        0
 ttyskeepawake        1
 hibernatemode        3
 gpuswitch            2
 powernap             0
 displaysleep         2
 sleep                1
 acwake               0
 halfdim              1
 tcpkeepalive         1
 lessbright           1
 disksleep            10
AC Power:
 lidwake              1
 autopoweroff         1
 proximitywake        1
 standby              1
 ttyskeepawake        1
 hibernatemode        3
 powernap             1
 gpuswitch            2
 womp                 1
 displaysleep         0
 networkoversleep     0
 sleep                1
 tcpkeepalive         1
 halfdim              1
 acwake               0
 disksleep            10
Alors pourquoi ce bug réapparait après une installation du MacOS ???
Certainement est-ce dû au fait que le ssd n'est pas "propriétaire" Apple ?
Je vais restaurer les paramètres de l'hibernation suivant les instructions de macromaniac proposées dans son message #4
Bonjour lasperule
Tu n'es pas sans noter le caractère délirant de ce paramétrage par défaut sur batterie -->
- sommeil-système après 1' d'inactivté en session. Trop court > ce qui surclasse le sommeil-écran = 2' & le sommeil-disque 10' qui n'interviennent donc jamais.​
- mode d'hibernation = 3 (défaut sur un portable) > qui détermine une sauvegarde de la RAM au disque mais un maintien de la RAM sous tension tout le temps du sommeil-système. Ce qui fait s'épuiser la batterie si le temps du sommeil-système s'éternise.​
- or il va s'éterniser > puisque l'hibernation est fixée à un délai de 86400" = 24 H de sommeil-système (charge de batterie à +50% au départ) > sinon à 3H en cas de charge à -50% au départ (cas rare). Donc le Mac ne vire jamais à l'hibernation et garde en tension la RAM ce qui épuise la batterie.​
- quant au sommeil-profond (norme européenne redondante d'économie d'énergie) => elle fixe un délai de 72H de sommeil-système = absurdité totale.​
Je t'invite donc à appliquer la commande antérieure qui va supprimer ce paramétrage complètement délirant.
Merci macomaniac :cool:
C'est ce que j'ai fait.
Mais as-tu une idée sur qu'est-ce qui fait que ces paramètres prennent, par défaut après installation, des valeurs "délirantes" comme tu dis ? :happy:
