10.15 Catalina "Le volume cible fait partie d'un système incomplet et ne peut pas faire l'objet d'une installation"
Ah ! enfin...
- repasse la commande :​
diskutil ap deleteContainer disk2 "Macintosh HD"
  • et poste le retour.
:merci:
-bash-3.2# diskutil ap deleteContainer disk2 "Macintosh HD"
Unmounting Volumes
Unmounting Volume "Macintosh HD - Données" on disk2s1
Unmounting Volume "Preboot" on disk2s2
Unmounting Volume "Recovery" on disk2s3
Unmounting Volume "VM" on disk2s4
Unmounting Volume "Macintosh HD" on disk2s5
Unmounting Volume "Molka" on disk2s6
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Initialized /dev/rdisk0s2 as a 113 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
Finished APFS operation on disk2
-bash-3.2#
Encore une commande et ça va le faire.
- passe la commande :​
diskutil ap convert disk0s2
  • qui reconvertit Macintosh HD à l'apfs (requis : Catalina ne s'installe qu'à destination d'un volume en format apfs)
-bash-3.2# diskutil ap convert disk0s2
Converting the volume on disk0s2 to an APFS Volume on an APFS Container
Started APFS operation on disk0s2 Macintosh HD
Converting HFS Volume to an APFS Container which will export one APFS Volume
The target is the Journaled HFS+ volume "Macintosh HD" backed by the GPT partition disk0s2
The target is a macOS system disk
Found APFS EFI driver /usr/standalone/i386/apfs.efi to install into the APFS Container
The target is not encrypted
Unmounting disk0s2
Starting conversion from HFS to APFS
Performing apfs_hfs_convert -x --verbose=0x400 --efi /usr/standalone/i386/apfs.efi /dev/disk0s2
Reporting pre-conversion statistics
Reporting post-conversion statistics
Successfully finished conversion from HFS to APFS
Successful conversion in commit mode so will switch type to APFS
Setting type of disk0s2 to APFS
Changing the physical disk partition type in shared mode
Partition modification attempt count was 1
Opening and closing disk0s2 to terminate old content driver
Expecting the new APFS Container at Physical Store disk0s2
Confirmed existence of new unencrypted APFS Volume disk2s1
Mounting APFS Volume disk2s1
APFS Volume mount attempt result was 0
Exiting conversion operations with error code 0
Disk from APFS operation: disk2s1
Finished APFS operation on disk0s2 Macintosh HD
-bash-3.2#
Parfait -->
- dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Réinstaller macOS" => et choisis Macintosh HD comme destination lorsque cela te sera proposé.​
Réactions: Artemisos
Il faut compter le temps de téléchargement de quelques 8 Go de paquets d'installation de Catalina.
- où en es-tu actuellement ?​
Ah je vois sachant, que ma connexion c'est pas Usain Bolt ça s'explique alors. La, il reste 1h18 mins. Je te tient au courant
C'est génial ! ça marche !!! Merci beaucoup pour ton aide et ta générosité, tu m'as réellement sauvé. :happy::happy:
Le problème initial qui m'a obligé a formaté n'est pas parti sinon, il s'est "atténué" et est devenu beaucoup moins embêtant (Maj qui s'enclenche toute seul, quand elle veux). Mais bon ça sera pour une prochaine fois, je ferai un poste spécifique pour l'occasion. :up:
Bonjour à tous
J’ai un souci similaire... j’avais plusieurs volumes que j’ai voulu supprimer pour n’avoir que « Macintosh HD » et depuis, impossible de re installer le système...
pourriez vous m’accompagner à réinstaller catalina sur mon MacBook Pro ?
Merci !
Bonjour Gilbert
Es-tu actuellement dans une session de secours (écran affichant une fenêtre de 4 Utilitaires macOS) ?
Pour la faire courte j’étais sous Catalina et ça marchait très bien. J’ai utilisé un de mes logiciels pour le travail qui connaissait quelques bugs. L’assistance Apple m’a demandé de passer big sur. Ça n’a pas améliorer mon Bug. C’est en voulant repasser sous Catalina que j’ai dû faire la fausse manip et effacer quelque chose qui n’aurait pas dû l‘être. Au début tout fonctionnait bien j’ai réussi. Mais je me suis aperçu que j’avais de nombreux disques durs qui étaient apparu dans l’arborescence de gauche. C’est en voulant les supprimer que j’ai du mettre le bazar… J’ai essayé de corriger en créant un nouveau des volumes, mais ça ne change rien… Mon ordinateur ne démarre plus sauf quand j’appuie sur la touche commande R
J’ai bien une sauvegarde Time Machine mais elle est sous big sur. En même temps si j’ai planté mon disque dur, j’ai un petit peu peur d’essayer de la réinstaller par-dessus et de tout reprendre à zéro pour repasser sous Catalina… Bref j’ai vraiment peur d’avoir ruiné mon appareil…
Voici comment tu vas pouvoir fournir ici les informations de base (tuto) -->
- aucune option de la fenêtre des 4 Utilitaires macOS lancée => va à la barre de menus supérieure de l'écran > menu : Utilitaires > sous-menu : Terminal.​
Dans la fenêtre ouverte > saisis la commande informative (ce qui est inscrit sous Bloc de code) :
diskutil list internal
  • tu vas voir s'afficher la configuration du disque interne seule
  • - en bas de cette page des forums MacGé => utilise le menu (le 16è depuis la gauche = vers le milieu de la barre) dans la barre de menus au-dessus du champ de saisie d'un message > sous-menu : </> (= Bloc de code) => tu fais ton coller dans la fenêtre de code et Continuer.
Note 1 : si tu ne peux pas poster via le Safari de la session de secours (ça arrive) --> poste une photo du tableau (à partir du commencement = le disque /dev/disk0 ou disque physique interne) - tu as un bouton : "Joindre un fichier" en bas de cette page.
-bash-3.2# diskutil list
   2:                 Apple_APFS Container disk2         1.0 TB     disk0s2
/dev/disk1 (disk image):
   1:                  Apple_HFS macOS Base System       2.0 GB     disk1s1
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +1.0 TB     disk2
   1:                APFS Volume Macintosh HD - Données  274.8 MB   disk2s1
   2:                APFS Volume Preboot                 82.7 MB    disk2s3
   3:                APFS Volume Recovery                529.0 MB   disk2s4
   4:                APFS Volume VM                      1.1 GB     disk2s5
   5:                APFS Volume Macintosh HD            11.0 GB    disk2s7
/dev/disk3 (disk image):
   0:                            untitled               +10.5 MB    disk3
/dev/disk4 (disk image):
   0:                            untitled               +10.5 MB    disk4
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
   0:                            untitled               +2.1 MB     disk8
/dev/disk9 (disk image):
/dev/disk10 (disk image):
   0:                            untitled               +524.3 KB   disk10
/dev/disk11 (disk image):
   0:                            untitled               +12.6 MB    disk11
/dev/disk12 (disk image):
   0:                            untitled               +4.2 MB     disk12
/dev/disk13 (disk image):
/dev/disk14 (disk image):
   0:                            untitled               +2.1 MB     disk14
/dev/disk15 (disk image):
/dev/disk16 (disk image):
   0:                            untitled               +2.1 MB     disk16
/dev/disk17 (disk image):
/dev/disk18 (disk image):
   0:                            untitled               +1.0 MB     disk18
/dev/disk19 (disk image):
/dev/disk20 (disk image):
   0:                            untitled               +6.3 MB     disk20
/dev/disk21 (disk image):
   0:                            untitled               +6.3 MB     disk21
/dev/disk22 (disk image):
   0:                            untitled               +524.3 KB   disk22
/dev/disk23 (disk image):
   0:                            untitled               +2.1 MB     disk23
/dev/disk24 (disk image):
   0:                            untitled               +10.5 MB    disk24
/dev/disk25 (disk image):
   0:                            untitled               +2.1 GB     disk25
-bash-3.2# diskutil list internal
-bash-3.2#
Je vois une distribution à 5 volumes de type Catalina (1 volume-Système de 11 Go à taille fixe > 1 volume-Données de 274 Go à taille variable > 3 volumes auxiiaires).
- on inspecte cette distribution pour voir si elle est fonctionnelle. Passe la commande :​
ls /Vol*/Mac*\Do*
  • pour taper la barre inverse \ tu utilises les 3 touches ⌥⇧: (ou alt maj :). Mais tu peux aussi bien faire un copier-coller à rebours : tu copies d'abord la commande ici avec Safari > tu la colles dans le terminal > tu l'exécutes
  • la commande liste les objets de 1er rang (fichiers ou dossiers) du volume-Données
ls /Vol*/Mac*\Do*
merci beaucoup de ton aide.
voila ce que j'obtiens:
-bash-3.2# ls /Vol*/Mac*\Do*
.fseventsd        macOS Install Data
-bash-3.2#
