/dev/disk1 (synthesized):
#: TYPE NAME SIZE IDENTIFIER
0: APFS Container Scheme - +420.0 GB disk1
Physical Store disk0s2
1: APFS Volume VM 3.2 GB disk1s4
2: APFS Volume Preboot 20.3 MB disk1s2
3: APFS Volume Recovery 523.5 MB disk1s3
diskutil ap convert disk0s2
diskutil list
/dev/disk0 (internal):
0: GUID_partition_scheme 500.3 GB disk0
1: EFI EFI 314.6 MB disk0s1
2: Apple_APFS Container disk1 419.9 GB disk0s2
3: Apple_APFS Container disk2 80.0 GB disk0s3
0: APFS Container Scheme - +419.9 GB disk1
1: APFS Volume Macintosh HD 933.9 KB disk1s1
/dev/disk2 (synthesized):
0: APFS Container Scheme - +80.0 GB disk2
Physical Store disk0s3
1: APFS Volume SOS 53.6 GB disk2s1
2: APFS Volume Preboot 24.0 MB disk2s2
3: APFS Volume Recovery 519.0 MB disk2s3
4: APFS Volume VM 3.2 GB disk2s4
diskutil list
1: APFS Volume Macintosh HD 51.9 GB disk1s1
3: APFS Volume Recovery 531.9 MB disk1s3
1: APFS Volume SOS 53.7 GB disk2s1
Oui, là je me retrouve avec une session conforme à la précédenteest-ce que tu retrouves une session conforme à la précédente de SOS ?
diskutil list
1: APFS Volume Macintosh HD 52.3 GB disk1s1
2: APFS Volume Preboot 24.0 MB disk1s2
4: APFS Volume VM 1.1 GB disk1s4
1: APFS Volume SOS 52.4 GB disk2s1
diskutil ap deleteContainer disk2
diskutil list
Started APFS operation
Aligning grow delta to 80'097'390'592 bytes and targeting a new physical store size of 499'963'170'816 bytes
Determined the maximum size for the targeted physical store of this APFS Container to be 499'962'142'720 bytes
Verifying storage system
Using live mode
Checking volume
Checking the space manager
Checking the object map
warning: apfs_sb at apfs_fs_index (0): apfs_formatted_by.timestamp is invalid (1534181144000000000), is greater than current time (1534180985904602000)
Checking the fsroot tree
Checking the extent ref tree
Checking the snapshots
Checking snapshot 1 of 1
Verifying allocated space
Growing APFS Physical Store disk0s2 from 419'865'780'224 to 499'963'170'816 bytes
Modifying partition map
Growing APFS data structures
Finished APFS operation
2: Apple_APFS Container disk1 500.0 GB disk0s2
0: APFS Container Scheme - +500.0 GB disk1
1: APFS Volume Macintosh HD 52.6 GB disk1s1
Pfuiiiit !
De ta session de SOS --> il sera possible de supprimer le Conteneur apfs du haut et de réinstaller High Sierra (ce qui recréera l'apfs). De la session du nouveau Macintosh HD du haut --> il sera possible de supprimer le Conteneur apfs du bas (avec le volume SOS) > puis de récupérer cet espace.
Je trouve ça poilant.
Pfuiiiit !
Bonjour EliHoney
Tu ne reconnais peut-être dans les tribulations de Deni (ton précurseur dans ce fil). Mais je ne connais pas pour ma part ce dénominateur commun.
Est-ce que ton OS est High Sierra ? - le disque de ton Mac est-il un SSD ? - peux-tu ouvrir normalement ta session d'utilisateur ?
Je viens de m'aviser après coup que tu as créé un fil original ici : ☞Récupérer 90 go de disque après partition pour reinstallation de systèmes☜
- je te propose de continuer cette conversation dans cet autre fil que je viens de citer. Passe la commande demandée et postes-y le tableau retourné.
MacBook-de-Eli:~ elirakotoarisoa$ diskutil list
2: Apple_APFS Container disk1 400.0 GB disk0s2
3: Apple_APFS Container disk2 100.0 GB disk0s3
0: APFS Container Scheme - +400.0 GB disk1
1: APFS Volume Macintosh HD 5.2 GB disk1s1
2: APFS Volume Preboot 43.3 MB disk1s2
3: APFS Volume Recovery 1.0 GB disk1s3
0: APFS Container Scheme - +100.0 GB disk2
1: APFS Volume SOS 11.5 GB disk2s1
2: APFS Volume Preboot 23.0 MB disk2s2
4: APFS Volume VM 1.1 GB disk2s4
