10.13 High Sierra Impossible de créer un volume de pré-démarrage pour l’installation apfs
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Forêt de Fontainebleau
Passe d'abord la commande :
df -H
  • qui mesure l'occupation des volumes montés
Poste le tableau. Il permettra de comparer l'occupation du clone et celle de la source.
Calnero
Membre junior
8 Janvier 2020
65
df -H
-bash-3.2# df -H
Filesystem      Size   Used  Avail Capacity iused               ifree %iused  Mounted on
/dev/disk2s1    2.0G   1.3G   733M    64%   50287          4294916992    0%   /
devfs           214k   214k     0B   100%     724                   0  100%   /dev
/dev/disk4      5.2M   1.1M   4.1M    22%      43          4294967236    0%   /private/var/log
/dev/disk5      524k   147k   377k    29%       5          4294967274    0%   /Volumes
/dev/disk6      524k   147k   377k    29%       7          4294967272    0%   /private/var/tmp
/dev/disk7      524k   160k   365k    31%      15          4294967264    0%   /private/var/run
/dev/disk8      2.1M   143k   2.0M     7%       2          4294967277    0%   /private/tmp
/dev/disk9      524k   143k   381k    28%       2          4294967277    0%   /System/Installation
/dev/disk10     524k   307k   217k    59%      20          4294967259    0%   /private/var/db
/dev/disk11      13M   7.1M   5.5M    57%     219          4294967060    0%   /private/var/folders
/dev/disk12     4.2M   573k   3.6M    14%      60          4294967219    0%   /private/var/root/Library
/dev/disk14     2.1M   381k   1.7M    19%      76          4294967203    0%   /private/var/root/Library/Containers
/dev/disk15     524k   201k   324k    39%      12          4294967267    0%   /Library/Preferences
/dev/disk16     524k   164k   360k    32%       6          4294967273    0%   /Library/Preferences/SystemConfiguration
/dev/disk17     1.0M   193k   856k    19%       8          4294967271    0%   /Library/Keychains
/dev/disk18     524k   143k   381k    28%       2          4294967277    0%   /Library/Security/Trust Settings
/dev/disk19     6.3M   176k   6.1M     3%       2          4294967277    0%   /private/var/tmp/RecoveryTemp
/dev/disk20     6.3M   176k   6.1M     3%       2          4294967277    0%   /private/var/tmp/OSISPredicateUpdateProductTemp
/dev/disk21     524k   143k   381k    28%       2          4294967277    0%   /private/var/tmp/InstallerCookies
/dev/disk22     2.1M   143k   2.0M     7%       2          4294967277    0%   /Library/Logs/DiagnosticReports
/dev/disk3s1    3.1T   1.8T   1.3T    58% 2312250 9223372036852463557    0%   /Volumes/Macintosh HD
/dev/disk24s1    10T   157G   9.8T     2% 2249786 9223372036852526021    0%   /Volumes/Clone
-bash-3.2#
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Il n'y a que 157 Go d'occupation de Clone contre 1,8 To pour la source Macintosh HD. Ce qui fait un énorme déficit !
- tu es sûr qu'il n'y a pas eu un arrêt en cours de clonage ?​
Calnero
Membre junior
8 Janvier 2020
65
Je l'ai laissé cette nuit et cet apres midi et il etait bien toujours allumé a mon retour avec -bash-3.2# en derniere ligne.
Peut etre que c'est le deuxieme disque (le SSD) du Fusion Drive qui a été cloné seulement, je crois que sa taille tourne autour des 200Go. Sinon je ne sais pas ce qui a pu se produire. Il y a t'il une solution ?
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Passe la commande :
/Vol*/Macin*/usr/bin/du -sh /Vol*/Macin*/*
  • respecte tous les * qui servent d'abréviations
  • la commande va chercher l'utilitaire de mesure des fichiers du (disk_usage) dans Macintosh HD (du est absent des ressources d'un OS de secours démarré) => et lui fait mesurer (en Gi = gibibytes : base 2) les dossiers de 1er rang de Macintosh HD. Commande très lente à s'exécuter. Attends le retour de -bash-3.2# en signal de fin.
Calnero
Membre junior
8 Janvier 2020
65
Passe la commande :
-bash-3.2# /Vol*/Macin*/usr/bin/du -sh /Vol*/Macin*/*
bash: /Volumes/Macintosh HD/usr/bin/du: Device not configured
-bash-3.2#
Ai je fais une erreur de frappe ?
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Non : commande bien saisie. Je n'interprète pas le retour : "device not configured" (appareil non configuré) - pour un fichier exécutable.
- on peut tenter un contournement. Lance Safari > va à sa barre de menu > Safari > Préférences > Général. Clique l'onglet tout à droite de la rubrique (en bas) : "Emplacement de téléchargement des fichiers" > navigue au volume Clone > Sélectionner.​
Préviens quand c'est fait.
Calnero
Membre junior
8 Janvier 2020
65
C'est fait
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Maintenant > viens avec Safari à cette page-ci. Utilise ce lien : ☞du.dmg☜ qui va faire télécharger dans Clone une image-disque du.dmg de 8 Mo depuis le dossier public de ma DropBox.
- l'image-disque contient un fichier du. Préviens quand c'est fait.​
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Passe la commande :
hdiutil attach /Vol*/Clone/du*
  • qui attache au Système du Mac le disque virtuel de l'image-disque du.dmg (hébergée dans Clone) => ce qui a pour effet de monter son volume
Calnero
Membre junior
8 Janvier 2020
65
Passe la commande :
-bash-3.2# hdiutil attach /Vol*/Clone/du*
/dev/disk0              GUID_partition_scheme
/dev/disk0s1            Apple_HFS                          /Volumes/du
-bash-3.2#
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Bon. Le volume du est monté et il contient le fichier du. L'adresse initiale à la commande est donc : /Vol*/du/du (ce qui est plus court à saisir que /Vol*/Macin*/usr/bin/du). J'espère seulement que l'utilitaire en question est compatible (je ne sais plus de quel OS je l'ai tiré).
- passe la commande :​
/Vol*/du/du -sh /Vol*/Macin*/*
  • et poste le retour.
Calnero
Membre junior
8 Janvier 2020
65
-bash-3.2# /Vol*/du/du -sh /Vol*/Macin*/*
 73G    /Volumes/Macintosh HD/Applications
794M    /Volumes/Macintosh HD/ConsequenceInstruments
1,7M    /Volumes/Macintosh HD/Incompatible Software
  0B    /Volumes/Macintosh HD/Informations sur l’utilisateur
170G    /Volumes/Macintosh HD/Library
  0B    /Volumes/Macintosh HD/Network
 17G    /Volumes/Macintosh HD/System
1,4T    /Volumes/Macintosh HD/Users
  0B    /Volumes/Macintosh HD/Volumes
2,5M    /Volumes/Macintosh HD/bin
  0B    /Volumes/Macintosh HD/cores
  0B    /Volumes/Macintosh HD/dev
  0B    /Volumes/Macintosh HD/etc
  0B    /Volumes/Macintosh HD/home
  0B    /Volumes/Macintosh HD/installer.failurerequests
  0B    /Volumes/Macintosh HD/net
 11G    /Volumes/Macintosh HD/private
1,0M    /Volumes/Macintosh HD/sbin
  0B    /Volumes/Macintosh HD/tmp
443M    /Volumes/Macintosh HD/usr
  0B    /Volumes/Macintosh HD/var
-bash-3.2#
Et voila
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
Ça a fonctionné.
- je vois que tu as 1,4 Ti = 1,5 To dans les Utilisateurs (qui contiennent ton dossier de compte).​
=> est-ce que ça te paraît correspondre à tes données ?
Calnero
Membre junior
8 Janvier 2020
65
Bon. Passe encore la commande parallèle :
/Vol*/du/du -sh /Vol*/Clone/*
  • qui mesure pareillement les dossiers de 1er rang de Clone
-bash-3.2# /Vol*/du/du -sh /Vol*/Clone/*
 64G    /Volumes/Clone/Applications
  0B    /Volumes/Clone/ConsequenceInstruments
4,0K    /Volumes/Clone/Incompatible Software
  0B    /Volumes/Clone/Informations sur l’utilisateur
 28G    /Volumes/Clone/Library
  0B    /Volumes/Clone/Network
 13G    /Volumes/Clone/System
 38G    /Volumes/Clone/Users
  0B    /Volumes/Clone/Volumes
2,2M    /Volumes/Clone/bin
  0B    /Volumes/Clone/cores
  0B    /Volumes/Clone/dev
8,2M    /Volumes/Clone/du.dmg
  0B    /Volumes/Clone/etc
  0B    /Volumes/Clone/home
4,0K    /Volumes/Clone/installer.failurerequests
  0B    /Volumes/Clone/net
2,3G    /Volumes/Clone/private
1,2M    /Volumes/Clone/sbin
  0B    /Volumes/Clone/tmp
751M    /Volumes/Clone/usr
  0B    /Volumes/Clone/var
-bash-3.2#
macomaniac
Ouroboros
20 Septembre 2012
68 112
21 081
En comparant les 2 tableaux > on voit qu'il n'y a pas eu interruption du clonage. Mais la recopie a systématiquement amoindri la taille en fichiers des dossiers clonés - comme si des masses de fichiers étaient inaccessibles en lecture et donc échappés de clonage.
- veux-tu qu'on fasse une seconde passe de clonage > avec une option de mise-à-jour qui fera que seules les différences de la source sur la destination seront clonées ?​
Calnero
Membre junior
8 Janvier 2020
65
Allons-y
