Dommage!! Merci MacomaniacJe suis hors domaine en ce qui concerne ce genre de question.
- il faudrait qu'un visiteur de ce fil qui s'y connaisse => te donne son avis.
On peut s'arranger autrement. Passe la commande :
Bloc de code:diskutil ap resizeContainer disk1 116g jhfs+ BOOT 0b
- tu peux la passer en copier-coller à rebours : tu la copies ici avec Safari > tu la colles dans le terminal > tu l'exécutes
- la commande rétrécit le Conteneur apfs à 116 Go et crée indépendamment un volume BOOT de 5 Go environ
-bash-3.2# diskutil ap resizeContainer disk1 116g jhfs+ BOOT 0b
Started APFS operation
Aligning shrink delta to 5 018 210 304 bytes and targeting a new physical store size of 115 999 997 952 bytes
Determined the minimum size for the targeted physical store of this APFS Container to be 8 315 338 752 bytes
Verifying storage system
Using live mode
Checking volume
Checking the space manager
Checking the object map
Checking the fsroot tree
Checking the extent ref tree
Checking the snapshots
Verifying allocated space
Shrinking APFS Physical Store disk0s2 from 121 018 208 256 to 115 999 997 952 bytes
Shrinking partition
Modifying partition map
Initialized /dev/rdisk0s3 as a 5 GB case-insensitive HFS Plus volume with a 8192k journal
Mounting disk
Finished APFS operation
-bash-3.2#
asr restore --s / --t /Volumes/BOOT --erase --noprompt
-bash-3.2# asr restore --s / --t /Volumes/BOOT --erase --noprompt
Validating target...done
Validating source...done
Validating sizes...done
Restoring ....10....20....30....40....50....60....70....80....90....100
Verifying ....10....20....30....40....50....60....70....80....90....100
-bash-3.2#
diskutil list
-bash-3.2# diskutil list
/dev/disk0 (internal):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme 121.3 GB disk0
1: EFI EFI 314.6 MB disk0s1
2: Apple_APFS Container disk1 116.0 GB disk0s2
3: Apple_HFS OS X Base System 4.9 GB disk0s3
/dev/disk1 (synthesized):
0: APFS Container Scheme - +116.0 GB disk1
1: APFS Volume Macintosh HD 5.2 GB disk1s1
2: APFS Volume Preboot 20.5 KB disk1s2
3: APFS Volume Recovery 519.0 MB disk1s3
4: APFS Volume VM 2.1 GB disk1s4
/dev/disk2 (disk image):
0: untitled +5.2 MB disk2
/dev/disk3 (disk image):
0: untitled +524.3 KB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +2.1 MB disk6
/dev/disk7 (disk image):
0: untitled +524.3 KB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +12.6 MB disk9
/dev/disk10 (disk image):
0: untitled +4.2 MB disk10
/dev/disk11 (disk image):
0: untitled +1.0 MB disk11
/dev/disk12 (disk image):
0: untitled +2.1 MB disk12
/dev/disk13 (disk image):
0: untitled +524.3 KB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +1.0 MB disk15
/dev/disk16 (disk image):
0: untitled +6.3 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +524.3 KB disk18
/dev/disk19 (disk image):
0: untitled +2.1 MB disk19
-bash-3.2# diskutil ap deleteContainer disk1 "Macintosh HD"
Started APFS operation on disk1
Unmounting Volumes
Unmounting Volume "Macintosh HD" on disk1s1
Unmounting Volume "Preboot" on disk1s2
Unmounting Volume "Recovery" on disk1s3
Unmounting Volume "VM" on disk1s4
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Initialized /dev/rdisk0s2 as a 108 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
Finished APFS operation on disk1
-bash-3.2#
Opération réussie -->
- dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Réinstaller macOS" => et choisis Macintosh HD comme destination lorsque cela te sera proposé.
0: GUID_partition_scheme *121.3 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk3 121.1 GB disk0s2
0: GUID_partition_scheme +2.1 GB disk2
1: Apple_HFS macOS Base System 2.0 GB disk2s1
/dev/disk3 (synthesized):
0: APFS Container Scheme - +3.1 TB disk3
1: APFS Volume Macintosh HD 1.8 TB disk3s1
2: APFS Volume Preboot 24.0 MB disk3s2
3: APFS Volume Recovery 507.4 MB disk3s3
4: APFS Volume VM 24.6 KB disk3s4
0: untitled +5.2 MB disk4
0: untitled +524.3 KB disk6
0: untitled +2.1 MB disk8
0: untitled +524.3 KB disk9
0: untitled +524.3 KB disk10
0: untitled +12.6 MB disk11
0: untitled +4.2 MB disk12
0: untitled +1.0 MB disk13
0: untitled +2.1 MB disk14
0: untitled +524.3 KB disk15
0: untitled +524.3 KB disk16
0: untitled +1.0 MB disk17
0: untitled +6.3 MB disk19
/dev/disk20 (disk image):
0: untitled +6.3 MB disk20
/dev/disk21 (disk image):
0: untitled +524.3 KB disk21
/dev/disk22 (disk image):
0: untitled +2.1 MB disk22
-bash-3.2#
diskutil ap list
Bonjour Calnero
J'avise une anomalie qui est la suivante -->
- le seul disque interne affiché est le disk0 : SSD de 121 Go > avec une partition principale de type apfs.- le Conteneur apfs (espace-disque virtuel) exporté comme disk3 => a une taille de 3,1 To > avec un volume Macintosh HD d'une occupation de 1,8 To- il manque donc à l'affiche un second disque interne > qui serait un HDD de 3 To. De sorte que le Conteneur apfs dépendrait d'un Fusion Drive de type apfs > solidarisant les 2 disques : SSD & HDD.
Passe la commande :
Bloc de code:diskutil ap list
- qui affiche un tableau détaillé de l'apfs
Poste ce tableau.
-bash-3.2# diskutil ap list
APFS Container (1 found)
+-- Container disk3 3237709C-9B55-4575-BF05-9AB1F9883D24
APFS Container Reference: disk3
Size (Capacity Ceiling): 3121506295808 B (3.1 TB)
Capacity In Use By Volumes: 1810425937920 B (1.8 TB) (58.0% used)
Capacity Not Allocated: 1311080357888 B (1.3 TB) (42.0% free)
+-< Physical Store disk0s2 C536C826-A4BF-4792-BC43-FE485214EB1D
| APFS Physical Store Disk: disk0s2
| Size: 121123069952 B (121.1 GB)
+-> Volume disk3s1 3C68DC77-7D43-3EA8-BF5D-63275A98B593
| APFS Volume Disk (Role): disk3s1 (No specific role)
| Name: Macintosh HD (Case-insensitive)
| Mount Point: /Volumes/Macintosh HD
| Capacity Consumed: 1800852631552 B (1.8 TB)
| FileVault: No
+-> Volume disk3s2 CCD64AB2-303D-4AC2-A2ED-71D5F5E80BEA
| APFS Volume Disk (Role): disk3s2 (Preboot)
| Name: Preboot (Case-insensitive)
| Mount Point: Not Mounted
| Capacity Consumed: 24006656 B (24.0 MB)
| FileVault: No
+-> Volume disk3s3 9936E164-B2E6-4BFA-968E-51216D25BC34
| APFS Volume Disk (Role): disk3s3 (Recovery)
| Name: Recovery (Case-insensitive)
| Capacity Consumed: 507416576 B (507.4 MB)
| FileVault: No
+-> Volume disk3s4 DC4F69FB-2CF5-42DC-80F5-CB9FD8516E8E
APFS Volume Disk (Role): disk3s4 (VM)
Name: VM (Case-insensitive)
Capacity Consumed: 24576 B (24.6 KB)
FileVault: No
-bash-3.2#
diskutil list internal
J'ai redémarré et voici ce que j'obtiens pour cet commande:Toujours aucune trace d'un disk1 qui serait un HDD de 3 To -->
- est-ce que tu peux redémarrer une fois (Menu > Redémarrer) > et presser aussitôt les 2 touches ⌘R pour réouvrir la session de secours ? - passe alors la commande :Bloc de code:diskutil list internal
- qui affiche la seule configuration des disques internes
Poste le tableau => qu'on voie si le HDD est ré-apparu attaché au Système du Mac.
-bash-3.2# diskutil list internal
2: Apple_APFS Container disk2 121.1 GB disk0s2
0: GUID_partition_scheme *3.0 TB disk1
1: EFI EFI 209.7 MB disk1s1
2: Apple_APFS Container disk2 3.0 TB disk1s2
/dev/disk2 (synthesized):
0: APFS Container Scheme - +3.1 TB disk2
Physical Stores disk0s2, disk1s2
1: APFS Volume Macintosh HD 1.8 TB disk2s1
2: APFS Volume Preboot 24.0 MB disk2s2
3: APFS Volume Recovery 507.4 MB disk2s3
4: APFS Volume VM 24.6 KB disk2s4
-bash-3.2#
diskutil ap list
Le disk1 de 3 To a refait son apparition. Repasse la commande :
- et reposte le tableau détaillé de l'apfs => que je voie si le Fusion Drive est en ordre.
+-- Container disk2 3237709C-9B55-4575-BF05-9AB1F9883D24
APFS Container Reference: disk2 (Fusion)
| APFS Physical Store Disk: disk0s2 (Main)
+-< Physical Store disk1s2 490B828E-79AF-4742-BAD1-3DCF79E2A6D7
| APFS Physical Store Disk: disk1s2 (Secondary, Designated Aux Use)
| Size: 3000383225856 B (3.0 TB)
+-> Volume disk2s1 3C68DC77-7D43-3EA8-BF5D-63275A98B593
| APFS Volume Disk (Role): disk2s1 (No specific role)
| FileVault: No
+-> Volume disk2s2 CCD64AB2-303D-4AC2-A2ED-71D5F5E80BEA
| APFS Volume Disk (Role): disk2s2 (Preboot)
| FileVault: No
+-> Volume disk2s3 9936E164-B2E6-4BFA-968E-51216D25BC34
| APFS Volume Disk (Role): disk2s3 (Recovery)
| Mount Point: /Volumes/Image Volume
| FileVault: No
+-> Volume disk2s4 DC4F69FB-2CF5-42DC-80F5-CB9FD8516E8E
APFS Volume Disk (Role): disk2s4 (VM)
FileVault: No
-bash-3.2#
