diskutil eraseVolume jhfs+ SOS disk4s2
diskutil list
Last login: Mon Jun 15 19:16:11 on console
iMac:~ bourquetommy$ diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *1.0 TB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk1 1.0 TB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +1.0 TB disk1
Physical Store disk0s2
1: APFS Volume SSD 16.4 GB disk1s1
2: APFS Volume Preboot 18.8 MB disk1s2
3: APFS Volume Recovery 516.2 MB disk1s3
0: GUID_partition_scheme *124.2 GB disk2
1: EFI EFI 209.7 MB disk2s1
2: Apple_HFS sos 123.4 GB disk2s2
3: Apple_Boot Recovery HD 650.0 MB disk2s3
/dev/disk3 (disk image):
0: Apple_partition_scheme +2.0 TB disk3
1: Apple_partition_map 32.3 KB disk3s1
2: Apple_HFSX Copies de sauvegarde... 2.0 TB disk3s2
diskutil eraseDisk apfs SSD gpt disk0
Last login: Tue Jun 16 06:36:05 on ttys000
iMac:~ bourquetommy$ diskutil eraseDisk apfs SSD gpt disk0
Started erase on disk0
Unmounting disk
Error: -69877: Couldn't open device
diskutil ap deleteContainer disk1 SSD
Unmounting disk
iMac:~ bourquetommy$ diskutil ap deleteContainer disk1 SSD
Started APFS operation on disk1
Unmounting Volumes
Unmounting Volume "SSD" on disk1s1
Unmounting Volume "Preboot" on disk1s2
Unmounting Volume "Recovery" on disk1s3
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Nom du modèle : iMac
Identifiant du modèle : iMac12,1
Nom du processeur : Intel Core i5
Vitesse du processeur : 2,7 GHz
Nombre de processeurs : 1
Nombre total de cœurs : 4
Cache de niveau 2 (par cœur) : 256 Ko
Cache de niveau 3 : 6 Mo
Mémoire : 16 Go
Version de la ROM de démarrage : 87.0.0.0.0
Version SMC (système) : 1.71f22
Numéro de série (système) : D25G7008DHJN
UUID du matériel : 70D31C50-DE27-50D9-8F79-95B8D363C8FA
