M
diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk1 480.0 GB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +480.0 GB disk1
Physical Store disk0s2
1: APFS Volume Macintosh HD 12.7 GB disk1s1
2: APFS Volume Preboot 22.6 MB disk1s2
3: APFS Volume Recovery 516.1 MB disk1s3
4: APFS Volume VM 1.1 GB disk1s4
0: FDisk_partition_scheme *4.0 GB disk2
1: DOS_FAT_32 DISK_IMG 4.0 GB disk2s1
MacBook-Pro-de-Mousskov:~ moussa$
diskutil eraseDisk jhfs+ CLE gpt disk2
MacBook-Pro-de-Mousskov:~ moussa$ diskutil eraseDisk jhfs+ CLE gpt disk2
Started erase on disk2
Unmounting disk
Creating the partition map
Formatting disk2s2 as Mac OS Extended (Journaled) with name CLE
Initialized /dev/rdisk2s2 as a 3 GB case-insensitive HFS Plus volume with a 8192k journal
Mounting disk
Finished erase on disk2
Bloc de code:diskutil eraseDisk jhfs+ CLE gpt disk2
- la commande initialise "Mac" la clé et monte un volume CLE
Poste l'affichage retourné.
sudo diskutil mount disk1s3 ; hdiutil attach /Volumes/Recovery/*/BaseSystem.dmg ; sudo asr restore --s /Volumes/"OS X Base System" --t /Volumes/CLE --erase --noprompt
MacBook-Pro-de-Mousskov:~ moussa$ sudo diskutil mount disk1s3 ; hdiutil attach /Volumes/Recovery/*/BaseSystem.dmg ; sudo asr restore --s /Volumes/"OS X Base System" --t /Volumes/CLE --erase --noprompt
Password:
Volume Recovery on disk1s3 mounted
Calcul de la somme de contrôle de Protective Master Boot Record (MBR : 0)…
Protective Master Boot Record (MBR : : vérifiée CRC32 $411E9678
Calcul de la somme de contrôle de GPT Header (Primary GPT Header : 1)…
GPT Header (Primary GPT Header : 1) : vérifiée CRC32 $5C699C2F
Calcul de la somme de contrôle de GPT Partition Data (Primary GPT Table : 2)…
GPT Partition Data (Primary GPT Tabl : vérifiée CRC32 $8E08CD46
Calcul de la somme de contrôle de (Apple_Free : 3)…
(Apple_Free : 3) : vérifiée CRC32 $00000000
Calcul de la somme de contrôle de disk image (Apple_HFS : 4)…
disk image (Apple_HFS : 4) : vérifiée CRC32 $601A54DD
Calcul de la somme de contrôle de (Apple_Free : 5)…
(Apple_Free : 5) : vérifiée CRC32 $00000000
Calcul de la somme de contrôle de GPT Partition Data (Backup GPT Table : 6)…
GPT Partition Data (Backup GPT Table : vérifiée CRC32 $8E08CD46
Calcul de la somme de contrôle de GPT Header (Backup GPT Header : 7)…
GPT Header (Backup GPT Header : 7) : vérifiée CRC32 $6DFB832D
vérifiée CRC32 $C27A36E3
/dev/disk3 GUID_partition_scheme
/dev/disk3s1 Apple_HFS /Volumes/OS X Base System
Validating target...done
Validating source...done
Validating sizes...done
Restoring ....10....20....30....40....50....60....70....80....90....100
Verifying ....10....20....30....40....50....60....70....80....90....100
diskutil list
diskutil list
diskutil ap deleteContainer disk2 "Macintosh HD"
