Probleme pour réallouer l'ancien espace bootcamp sur le disque dur macintosh
Alors passe les commandes (l'une après l'autre) :
diskutil repairDisk disk0
diskutil repairDisk disk1
  • après validation chaque fois > tu vas avoir une demande de confirmation --> tape y (comme yes) et revalide
  • les commandes réparent les tables de partitions des 2 disques
Poste bien les affichages retournés > surtout (s'il faut choisir en raison de la longueur) l'affichage de la 1ère
Repairing the partition map might erase disk0s1, proceed? (y/N) y
Started partition map repair on disk0
Checking prerequisites
Checking the partition list
Adjusting partition map to fit whole disk as required
Checking for an EFI system partition
Checking the EFI system partition's size
Checking the EFI system partition's file system
Checking the EFI system partition's folder content
Checking all HFS data partition loader spaces
Checking booter partitions
Checking booter partition disk0s3
Verifying file system
Volume is already unmounted
Performing fsck_hfs -fn -x /dev/rdisk0s3
Checking catalog file
Checking multi-linked files
Checking catalog hierarchy
Checking volume bitmap
Checking volume information
The volume Recovery HD appears to be OK
Restoring the original state found as unmounted
Reviewing boot support loaders
Checking Core Storage Physical Volume partitions
Verifying storage system
Performing fsck_cs -n -x --lv --uuid FEC55213-3959-4FEB-9EB8-184DA549BEEB
Checking volume
disk0s2: Scan for Volume Headers
disk1s2: Scan for Volume Headers
disk0s2: Scan for Disk Labels
disk1s2: Scan for Disk Labels
Logical Volume Group FEC55213-3959-4FEB-9EB8-184DA549BEEB spans 2 devices
disk1s2+disk0s2: Scan for Metadata Volume
Logical Volume Group has a 95 MB Metadata Volume with double redundancy
Start scanning metadata for a valid checkpoint
Load and verify Segment Headers
Load and verify Checkpoint Payload
Load and verify Transaction Segment
Incorporate 4 newer non-checkpoint transactions
Load and verify Virtual Address Table
Load and verify Segment Usage Table
Load and verify Metadata Superblock
Load and verify Logical Volumes B-Trees
Logical Volume Group contains 1 Logical Volume
Load and verify 87625B10-CFB5-4890-9BDB-AF18BEE8A285
Load and verify 6EFC2D4E-B466-4C6D-B196-56F3B64F6AC1
Load and verify Freespace Summary
Load and verify Block Accounting
Load and verify Live Virtual Addresses
Newest transaction commit checkpoint is valid
Load and verify Segment Cleaning
The volume FEC55213-3959-4FEB-9EB8-184DA549BEEB appears to be OK
Repairing storage system
Performing fsck_cs -y -x --lv --uuid FEC55213-3959-4FEB-9EB8-184DA549BEEB
The volume disk0s2+disk1s2 cannot be repaired when it is in use
Checking volume
Incorrect size for volume "Macintosh HD"
Adjusting volume "Macintosh HD"
Growing Logical Volume
Resizing Core Storage Logical Volume structures
Resized Core Storage Logical Volume to 1 995 999 936 512 bytes
Growing file system
The partition map appears to be OK
Finished partition map repair on disk0
Cette mention finale de la 1ère réparation -->
Growing file system
  • montre que l'erreur de taille interne a été corrigée avec succès
Passe une commande :
diskutil list
  • et poste le tableau des disques --> que je voie où en est la situation générale...
   0:      GUID_partition_scheme                        *2.0 TB     disk0
   2:          Apple_CoreStorage Macintosh HD            1.9 TB     disk0s2
   0:      GUID_partition_scheme                        *121.3 GB   disk1
   2:          Apple_CoreStorage Macintosh HD            121.0 GB   disk1s2
   3:                 Apple_Boot Boot OS X               134.2 MB   disk1s3
/dev/disk2 (disk image):
/dev/disk3 (internal, virtual):
   0:                  Apple_HFS Macintosh HD           +2.0 TB     disk3
                                 Logical Volume on disk1s2, disk0s2
                                 Unencrypted Fusion Drive
/dev/disk4 (disk image):
   0:                            untitled               +5.2 MB     disk4
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
   0:                            untitled               +2.1 MB     disk8
/dev/disk9 (disk image):
/dev/disk10 (disk image):
   0:                            untitled               +524.3 KB   disk10
/dev/disk11 (disk image):
   0:                            untitled               +12.6 MB    disk11
/dev/disk12 (disk image):
   0:                            untitled               +4.2 MB     disk12
/dev/disk13 (disk image):
/dev/disk14 (disk image):
   0:                            untitled               +2.1 MB     disk14
/dev/disk15 (disk image):
/dev/disk16 (disk image):
   0:                            untitled               +524.3 KB   disk16
/dev/disk17 (disk image):
   0:                            untitled               +1.0 MB     disk17
/dev/disk18 (disk image):
/dev/disk19 (disk image):
   0:                            untitled               +6.3 MB     disk19
/dev/disk20 (disk image):
   0:                            untitled               +524.3 KB   disk20
/dev/disk21 (disk image):
   0:                            untitled               +2.1 MB     disk21
Il y a toujours un déficit de 100 Go (me semble-t-il) d'espace libre en queue du HDD.
Passe la commande :
diskutil cs resizeStack 6EFC2D4E-B466-4C6D-B196-56F3B64F6AC1 0b
  • le copier-coller à rebours est ton ami pour cette saisie
  • la commande récupère l'espace libre au CoreStorage du Fusion Drive
Poste l'affichage retourné.
The Core Storage Logical Volume UUID is 6EFC2D4E-B466-4C6D-B196-56F3B64F6AC1
Started CoreStorage operation
Checking prerequisites for resizing Logical-Physical volume stack
Growing Logical-Physical volume stack
Volume was successfully unmounted
Performing fsck_hfs -fn -x /dev/rdisk3
The volume Macintosh HD appears to be OK
Restoring the original state found as mounted
Growing Core Storage Physical Volume from 1 880 866 516 992 to 1 999 539 175 424 bytes
Copying booter
Growing disk partition
Modifying partition map
Growing Core Storage data structures
Resizing Core Storage Physical Volume structures
Resized Core Storage Physical Volume to 1 999 539 175 424 bytes
Resized Core Storage Logical Volume to 2 114 672 525 312 bytes
Growing file system
Finished CoreStorage operation
Opération réussie -->
Growing file system
  • tu peux passer un ultime :
diskutil list
  • et poster le tableau --> qu'on contemple le paysage.
   2:          Apple_CoreStorage Macintosh HD            2.0 TB     disk0s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk0s4
   0:                  Apple_HFS Macintosh HD           +2.1 TB     disk3
  • cette ligne -->
  • montre que la partition n°2 du HDD a récupéré la totalité de l'espace possible du HDD = 2 To. Et cette ligne -->
  • montre que l'espace-disque virtualisé du Logical Volume et celui du volume Macintosh HD monté dessus --> ont récupéré la capacité maximale possible sur les 2 disques = 2,1 To
=> ton problème est résolu. Tu peux redémarrer sur Macintosh HD et réouvrir ta session. Je reviendrai plus tard dans ton fil pour "épiloguer"...
Je ne sais comment te remercier ... , tout ce temps que tu m'a consacrer ... Meric beaucoup , merci d'aider les personnes comme moi ,
Tu est clairement un monstre un informatique, merci .
Ton Fusion Drive était totalement bloqué pour 2 raisons : a) absence des 2 partitions auxiliaires EFI et Recovery HD sur le HDD > b) erreur de taille interne du dispositif CoreStorage (ce qui veut dire : espace virtuel exporté du Logical Volume plus petit que la capacité du magasin de stockage physique Physical Volume de la partition du HDD = un accident peu commun mais attesté).
Dans les conditions d'alors > si le volume de l'OS fonctionnait > tu ne pouvait ni envisager une réinstallation > ni une récupération de l'espace libre existant à la fin du HDD. Actuellement > tout est rentré dans l'ordre et ton Fusion Drive est fonctionnel.
Tu t'es bien accroché pour toutes les manipulations complexes qu'il fallait effectuer pour redresser la situation > sans faire d'erreurs dans la saisie des commandes. Pour moi ça a constitué une sorte de challenge "sportif".
Le seul déficit actuel est le suivant : le volume Recovery HD de la partition de secours ne contient pas d'OS de secours démarrable. Ce qui est bien commode parfois à l'usage. Comme ton OS actuel est El Capitan 10.11.6 --> il faudrait que tu récupères un installateur de cet OS > et que tu lances une réinstallation à destination du volume Macintosh HD démarré : tes données seraient préservées (et aussi les applications tierces) > le Système serait restauré > mais surtout en 1er lieu la partition de secours du HDD serait restaurée du contenu de son volume -->
  • est-ce que tu as les moyens de télécharger un tel installateur d'El Capitan depuis l'AppStore ? - il fait peut-être partie de tes Achats ?
