A l'heure actuelle, un disque dur vierge est soit formaté en FAT32, soit en NTFS.
Exact, il est en NTFS
-bash-3.2# diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk2 499.9 GB disk0s2
/dev/disk1 (disk image):
0: GUID_partition_scheme +2.1 GB disk1
1: Apple_HFS OS X Base System 2.0 GB disk1s1
/dev/disk2 (synthesized):
0: APFS Container Scheme - +499.9 GB disk2
Physical Store disk0s2
1: APFS Volume Macintosh HD 6.1 GB disk2s1
2: APFS Volume Preboot 19.8 MB disk2s2
3: APFS Volume Recovery 20.5 KB disk2s3
4: APFS Volume VM 5.4 GB disk2s4
/dev/disk3 (disk image):
0: untitled +5.2 MB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +524.3 KB disk6
/dev/disk7 (disk image):
0: untitled +2.1 MB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +524.3 KB disk9
/dev/disk10 (disk image):
0: untitled +12.6 MB disk10
/dev/disk11 (disk image):
0: untitled +4.2 MB disk11
/dev/disk12 (disk image):
0: untitled +1.0 MB disk12
/dev/disk13 (disk image):
0: untitled +2.1 MB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +524.3 KB disk15
/dev/disk16 (disk image):
0: untitled +1.0 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +6.3 MB disk18
/dev/disk19 (disk image):
0: untitled +524.3 KB disk19
/dev/disk20 (disk image):
0: untitled +2.1 MB disk20
-bash-3.2#
Bonjour Tony
Je vois que ton volume Macintosh HD ne contient que 6,1 Go de données = un dossier macOS Install Data contenant les paquets d'installation de Mojave (installation qui a dû avorter) -->
- qu'est-ce que tu veux faire actuellement ? - faire une installation propre ?
diskutil ap deleteContainer disk2 "Macintosh HD"
-bash-3.2# diskutil ap deleteContainer disk2 "Macintosh HD"
Unmounting Volumes
Unmounting Volume "Macintosh HD" on disk2s1
Unmounting Volume "Preboot" on disk2s2
Unmounting Volume "Recovery" on disk2s3
Unmounting Volume "VM" on disk2s4
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Initialized /dev/rdisk0s2 as a 465 GB case-insensitive HFS Plus volume with a 40960k journal
Mounting disk
Finished APFS operation on disk2
-bash-3.2#
Opération réussie. Tu disposes actuellement d'un volume Macintosh HD vide > dans un format Mac OS étendu (journalisé). Réinstallable.
- tu peux parfaitement attendre d'avoir ta clé USB et alors : démarrer dessus et installer Sierra à destination de Macintosh HD. Le volume va t'attendre bien sagement...
Tony
C'est possible, oui. Je t'envoie un MP.
Tony
Est-ce que tu as un DDE USB disponible ? - après paramétrage (table GUID pour le disque > format Mac OS étendu journalisé pour le volume) > tu pourrais relancer une installation à destination du volume du DDE :
- si l'installation s'effectue bien en externe (avec redémarrage du Mac > ouverture de session etc.) --> il faudrait conjecturer un problème matériel (disque ou nappe) > quand tu tentes une installation qui échoue en interne...
C'est un Kernel Panic. Pas toujours facile à analyser ; là, on dirait qu'il s'agit d'un problème lié au disque (au moment où l'on cherche à accéder à une partition pour la monter). Soit un problème physique (HDD, nappe ?) soit un problème logique (décalage entre ce que l'on est censé avoir et ce qu'on a réellement).
Installer sur un disque externe sera donc un bon test. Pas besoin d'avoir un gros disque externe. Mais il faut s'attendre à ce que ça soit un peu lent (c'est normal).
diskutil info disk0s2
